Home > Forums > Software User Forums > Fidelity CFD
Negative Volume In Block
Old   September 8, 2014, 12:03
Default Negative Volume In Block
Amirah
Myra Satuka is on a distinguished road
This problem make the solver crashed.
"Computation stop because of negative volumes.
Negative volume found in block."
How to overcome this problem?
What should I overlook?
Thank you.
Myra Satuka is offline   Reply With Quote
Old   September 11, 2014, 05:47
Romain
Rombzh is on a distinguished road
Did it crash soon after the run started ? Are you using mesh deformation ?
Do you witness significant amplitude motions ? It may be that at t=0s the body is quite far away from its final position, which leads to significant mesh deformation, which can lead to negative volumes.
Rombzh is offline   Reply With Quote
Old   November 19, 2014, 18:16
lucar4980 is on a distinguished road
You have to carefully check your mesh generation process. A common error is related to Unit value: double check it.
You may also try to refine the grid close to gaps or fillet (if there are any).
www.ampsolutions.it
lucar4980 is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
Negative Volume during Mesh Motion Analysis giov_ingr FLUENT 2 December 13, 2013 06:09
Courant number blowing up, non-orthogonal mesh? odellar OpenFOAM Running, Solving & CFD 5 October 22, 2013 19:50
Possible bug in blockMesh benru OpenFOAM Bugs 16 August 17, 2013 19:54
