Home > Forums > Software User Forums > Fidelity CFD
centrifugal compressor 1D vs. CFD
Old   March 3, 2017, 04:43
Default centrifugal compressor 1D vs. CFD
Piotr
piotr1987 is on a distinguished road
Simulating centrifugal compressor with vaneless diffuser i usually get good agreement with 1d calculation at impeller exit. However CFD shows much bigger static pressure growth along vaneless diffuser. I performed my calculation using SA turbulence model. I repeated computation using diffrent y wall, but tendency remains the same. Vaneless diffuser seems to be easy element to predict, so I believe 1d calculation are correct. Is it nature of mentioned turbulence model, that it can't predict accurate static pressure along static components ?
piotr1987 is offline   Reply With Quote
Old   March 3, 2017, 12:16
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
"Is it nature of mentioned turbulence model, that it can't predict accurate static pressure along static components ?"
Definitely not, the SA-Model is a well-proven turbulence model in many turbomachinery applications from my experience.
May I ask how much bigger the static pressure at the diffuser exit is (comparing 1D and CFD)? How do you obtain your 1D results, maybe from a preliminary design tool?
Maybe you want to share your boundary conditions (inlet / outlet) with us?
Secondly you could compare the SA-model with SST or EARSM model computations.
I am looking forward to hearing from you.
Holger
DarylMusashi is offline   Reply With Quote
Old   March 4, 2017, 03:19
Hamid Zoka
Hamidzoka is on a distinguished road
Hi;
One point that should be considered in turbomachinery design cycles like what you are doing now is the different natures of 1D and 3D design tools. 3D solver will never replicate results of a 1D code even being a perfect one. So, some difference is always seen between the two and I believe that even running a LES turbulence model will not fill this gap.
What is the difference level between the two?
To my experiences if the difference is large, As "DarylMusashi" mentioned, changing the turbulence model will not be helpful. In such a case it seems you need to recheck your 1D code or boundary conditions of your 3D model.
If the difference is not too much, changing some other settings like mesh sizes or turbulence model can always help lower the difference.
Regards
Hamidzoka is offline   Reply With Quote
cfd of centrifugal slurry pump casing mohitmak12 CFX 1 February 7, 2017 05:35
CFD Analysis of Centrifugal Pump Kamilva Main CFD Forum 0 May 17, 2016 08:11
Help me find an easy CFD software to model a Centrifugal Blower ! x.marX Main CFD Forum 1 May 11, 2016 03:39
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
