Home > Forums > Software User Forums > Fidelity CFD
CF View azimuthal averaged solution error
Like Tree1Likes
  • 1 Post By DarylMusashi
Old   October 27, 2017, 04:47
Default CF View azimuthal averaged solution error
Marco
MarcoPolo is on a distinguished road
Hello
I am currently busy running simulations of a mixed-flow compressor impeller, but get an error when I want to view the azimuthal averaged solution. I get the following error:
IO error in FileOpenProject: Input error in Run1_new_Run_1.12.3.me.cfv: cgns file 'Run' not found.
Am I possibly missing a specific selection that one should make to view the azimuthal averaged solution? Any advice would be greatly appreciated.
Kind regards
Marco
MarcoPolo is offline   Reply With Quote
Old   October 27, 2017, 08:07
DarylMusashi's Avatar
Holger Dietrich
DarylMusashi is on a distinguished road
I get a similiar, but not identical error in my case (....Input error in <filename>, Mesh base not found).
I guess in FINE/Turbo GUI you hit the CFView button in the top bar and checked the field "View the Azimuthal Averaged Solution"?
I don't know why this happens, but I would recommend to start CFView without activating this field. In CFView you start in the 3D View, please select File -> Turbomachinery -> OK. In the top left view you can visualize the Azimuthal Averaged Solution, too. If you miss a quantity in the azimuthal view, which you want to post process you can double-click it in the 3D View and then start the turbomachinery mode. Variables selected this way and even user-defined quantities are available in the turbo view then.
I hope this helps you to proceed.
Kind regards,
Holger
MarcoPolo likes this.
DarylMusashi is offline   Reply With Quote
azimuthal, cfv, postprocessing
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 20:30
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
