December 20, 2017, 06:09 |
Parallel computation with Fine/Open
Hi Pals,
I got the license file for the Fine/Open. The serial solver is available, but the parallel solver needs the credentials? How can I deal with it? Thanks in advance. |
December 21, 2017, 03:53 |
Holger Dietrich
Rep Power: 15 |
The "user credentials" are simply your windows user name/password. In the dialog please press <RETURN> in the user name line and enter your windows password.
The MPI process needs to write something in the registry to enable parallel computing. This is necessary if you do a parallel computation for the very first time on a machine. Kind regards, Holger Last edited by DarylMusashi; December 22, 2017 at 09:23. |
December 25, 2017, 03:16 |
#3 | |
Thanks very much. It works.
fine/open |
Scaling of parallel computation? Solver/thread count combinations? | tdof | OpenFOAM | 8 | January 13, 2022 11:39 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Serial UDF is working for parallel computation also | Tanjina | Fluent UDF and Scheme Programming | 0 | December 26, 2013 18:24 |
problem in the CFX12.1 parallel computation | BalanceChen | ANSYS | 2 | July 7, 2011 10:26 |
