December 19, 2017, 13:33 |
Hexpress - Anisotropic refinement Diffusion
FineOpen User
Rep Power: 9 |
I created a surface representing an aircraft wing. The cell size in the spanwise direction is 4 times bigger than the chordwise direction. Thus, in the surface refinement tab of Hexpress, the following settings were selected.
By looking on the generated mesh, I can see that the cells in the leading edge have the correct target size. However, the cells created by the diffusion process are isotropic ! When I changed the meshing strategy for the LE surface by using the curve refinement method and the same settings as above, the cells created by the diffusion process have now the correct aspect ratio. Is there a reason for this difference ? |
December 24, 2017, 11:48 |
FineOpen User
Rep Power: 9 |
Problem solved by increasing the intrados/extrados diffusion depth to 4.
anisotropic., fine, hexpress, isotropic, numeca |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 01:37 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 13:30 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
