Rep Power: 8 ![]() |
I created with Fine Turbo a new project and recorded this process (as you can see attached) with the "Edit" function of Fine Turbo. Afterwards I tried to execute this Macro, but nothing happened. Actually it should create a new project named "test" as I recorded before. Does anyone know why nothing happened? Thanks a lot. Greetings |
Holger Dietrich
Rep Power: 15 ![]() |
Dear dha_90,
this script works fine for me (tested on linux). You should figure out if you have the necessary rights to write in this folder. Secondly, you should always avoid blank spaces in file or folder names. You may start FINE/Turbo with the additional command "-print", is something helpful written in the shell after you executed this macro? Kind regards, Holger Last edited by DarylMusashi; February 5, 2018 at 16:26. |
Hello
Is it possible that I need to create a folder with the defined project name (in my case "test"). If I create a folder with the name and start the script again Numeca creates a project file in this folder. I thought this is not necessary cause when I recorded the macro there was no folder with the name "test". Numeca created a folder by itself. Greetings Last edited by dha_90; February 2, 2018 at 17:23. |
Holger Dietrich
No, you don't need. I still assume the problem might be that you are not allowed to create folders directly on the Desktop, but in a sub-folder.
[Workbench] Run ICEM Script in Workbench Script | MIZOR | ANSYS Meshing & Geometry | 9 | April 4, 2018 07:45 |
Shell script to handle Segmentation faults arising from execFlowFunctionObjects | pruthvi1991 | OpenFOAM Post-Processing | 0 | February 22, 2015 14:20 |
[ICEM] Generalize ICEM script for different sizes of same geometry. | Akash kumar | ANSYS Meshing & Geometry | 0 | November 16, 2014 08:38 |
CentFOAM Python Script Installation: Error | socon009 | OpenFOAM Installation | 2 | May 26, 2012 09:36 |
New NUMECA Forum Opened | Jonas Larsson | Main CFD Forum | 0 | February 16, 2003 10:25 |
