Home > Forums > Software User Forums > Fidelity CFD
Open Labs
Old   April 12, 2018, 03:37
Question Open Labs
Zaranyika Parents Kumbirai
EngZara is on a distinguished road
hello
i ahve gone through all the turtorials provided by the NUMECA package, I want to edit the PDE in OpenLabs. I want to change the N-S equation into the Vorticity Transport Equation and I am having difficulties with that. if i have a hint on how to implement this, the rest of my problems will be solved
http://brennen.caltech.edu/fluidbook...ytransport.pdf
EngZara is offline   Reply With Quote
Old   April 19, 2018, 07:13
Default OpenLabs
Colinda
colinda1 is on a distinguished road
That is not just slightly editing the PDE but quite a big modification.
To my knowledge this has not been tried before and I would not recommend to use OpenLabs™ for this.
May I ask what would be the reason to solve this vorticity transport equation rather than the NS momentum equation?
To solve as a fluid may not be so obvious for the following reasons:
- how to compute velocity from vorticity in 3D?
- In OpenLabs™ there is no functionality to replace the update of the velocity field (of the internal PDE's) by a dependent field.
- due to preconditioning, it is not possible to split velocity from the coupled NS system.
- how to deduce the pressure from this approach? Would you be interested in the pressure field?
You might consider to solve it as a solid block.
If we forget about pressure, turbulence, numerical robustness... you might try the following:
- use solid block
- define velocity by algebraic expressions
- define PDEs: omega_x, omega_y, omega_z
- define PDEs: psi_yz, psi_zx, psi_xy
steps: Initialize vorticity - solve stream function - solve velocity - solve vorticity
However we don't have confidence on this strategy, as there could be many other issues, like:
- Discretization of the convection term of vorticity PDE's WILL be an issue!
- Need investigations on the boundary conditions of stream function and vorticity PDEs.
- Linear solver for Poisson equation (the stream function) is Gauss-Seidel in OpenLabs, which is not optimal.
- Apply the connections for the PDEs on FNMB (Solid-Solid) if it is multiblock.
Best regards,
Colinda
Head NUMECA Academic Group.
colinda1 is offline   Reply With Quote
Old   May 8, 2018, 04:47
Colinda
OpenLabs cannot formulate the Biot-Savart Law. Moreover, as explained in my previous post, we cannot replace the momentum equations. The trick to define vorticity equations in solid block will face discretization problems as described in my previous post as well.
fine/open, numeca, openlabs
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 15:14
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
