May 8, 2018, 13:13 |
CFView Error in Opening solution File
Vishwas Verma
Rep Power: 10 |
Dear all,
I am getting IO error(please see attached) while trying to open solution file in CFView. I have ran the simulation on cluster in fine turbo 12.1, and transferred the solution file on local desktop. I am not exactly sure, why does CFView accepts some files and for other it shows this error. Could anyone please help. Kind regards Vishwas |
May 10, 2018, 23:56 |
Vishwas Verma
Rep Power: 10 |
I am still stuck at this point. Has anyone not encountered this issue earlier? I don't know why files are opening on server machine(post-processing on server is dead slow) but not on local desktop. Does anyone please can help to solve this issue ? thanks!! Regards Vishwas |
May 14, 2018, 02:47 |
Colinda
Rep Power: 14 |
Which solution files did you transfer to your local machine? Did you well transfer the entire computation folder or only a part of it? Did the simulation run sufficiently long to save a full solution that can be used for post processing or did you select to save such file 'at end only' and the simulation was stopped before the end? Best regards, Colinda |
May 17, 2018, 03:10 |
Vishwas Verma
Rep Power: 10 |
Dear Colinda,
Thanks for replying. I had transferred the complete directory of solution folder (files can be seen in attached snapshot). Also the solution is completely converged and stopped by itself, after satisfying the convergence criterion. Many Thanks!! Kind Regards Vishwas |
May 26, 2018, 22:52 |
Error CFview
Maful suranto
Rep Power: 7 |
If io error at open CFview fine marine, in under picture... Why?.please help me..
July 7, 2018, 02:52 |
Vishwas Verma
Rep Power: 10 |
found the solution for this problem. Actually the case was run on linux based OS, the local machine has windows OS. In linux distro, there is no issue in opening run files. Not sure why does this happen with only few cases. Regards vishwas |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
