Home > Forums > Software User Forums > Fidelity CFD
NUMECA Problem about Parallel Partitioned Computation
Old   October 13, 2019, 11:03
Default NUMECA Problem about Parallel Partitioned Computation
gaolingtao
Gone is on a distinguished road
I have a grid with H-O-H topology on B2B section, and it has three blocks. At first, i used parallel computation in FINE/TURBO, it is ok and I could get results. But it is too slow considering I could use three processes at most. So when I choosed parallel partitioned computation, it appeared "run time error" sometimes and sometimes it worked well.
And the .std file shows below:
check_feature 'Solver'
checking regular version
STARTING NUMECA FLOW SOLVER
Broadcasting the runfile
Building the project from broadcasted data
...done in 0-sec (Building the project from broadcasted data)
...done in 0-sec (Broadcasting the runfile)
Running the partitioning...
Assembling the initial block decomposition from the FINE topology...
...done in 0-sec (3 blocks found)
Virtualizing the patches
The following patches have not been connected: 1 INL patches, 1 OUT patches, 8 SOL patches,
ERROR: Not enough grid level to go from the fine to the coarse grid 0 patches involved in 0 FNMB
0 patches involved in 0 Rotor/Stator
0 patches involved in 0 Turbo NRBC
...done in 0-sec (Virtualizing the patches)
Gone is offline   Reply With Quote
Old   December 16, 2019, 05:51
veerappan
veera is on a distinguished road
i am also getting same problem
veera is offline   Reply With Quote
Old   December 20, 2019, 02:33
gaolingtao
You can see the .std files to find what the error is. If you encountered the same problem(Not enough grid level to go from the fine to the coarse grid), you can try to close the multigrid parameters(set current grid level 0 0 0) or adjust your grid.
Problem with foam-extend 4.0 ggi parallel run Metikurke OpenFOAM Running, Solving & CFD 1 December 6, 2018 15:51
SU2 Parallel Computation problem Gramanzini SU2 5 September 29, 2018 12:32
problem sampling a plane in parallel syavash OpenFOAM Post-Processing 0 May 7, 2018 10:15
Problem with parallel computation (case inviscid onera M6) Combas SU2 11 January 30, 2014 01:20
Strange post processing resuls for parallel computation of Onera M6 tutorial Akash C SU2 Shape Design 9 August 30, 2013 06:05
