Home > Forums > Software User Forums > Fidelity CFD
Export geomTurbo file in Autogrid
Old   December 4, 2021, 12:38
Default Export geomTurbo file in Autogrid
ulugbey is on a distinguished road
I am using Fine Turbo 14.2. I imported CAD file in Autogrid 5. I heard that there is a possibility to write out geomTurbofile from the imported CAD File. How can export geomTurbo file from the imported CAD File?
Thanks in advance!
Best regards
ulugbey is offline   Reply With Quote
Old   December 6, 2021, 03:25
Colinda
colinda1 is on a distinguished road
It is indeed possible to export to a geomTurbo file as described in detail in the user guide in the dedicated section of the Geometry definition chapter.
Btw, you may want to update your installation to 16.1 as the version 14.2 is quite outdated.
Best regards,
Colinda
colinda1 is offline   Reply With Quote
Old   December 19, 2021, 23:47
Hamid Zoka
Hamidzoka is on a distinguished road
hi;
Simply right click on the imported blade on the Autogrid screen and select export option. a window will appear which allows you modify settings of the exported geometry such as number of sections, number of points on each side, etc..
Before exporting the geometry, make sure that your imported blade has intersections with hub and shroud curves and inlet and outlet boundaries are generated at its upstream and downstream.
Best
Hamidzoka is offline   Reply With Quote
autogrid5, numeca fine/open
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 16:18
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 17:18
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
