Home > Forums > Software User Forums > Fidelity CFD
Can't get the same results with tutorials
Old   October 1, 2022, 12:07
Default Can't get the same results with tutorials
oab
oab
oab is on a distinguished road
Hello! I'm a beginner level user of NUMECA Fine Marine. To learn the basics of the software, I'm trying to perform the tutorials of NUMECA Online Documentation Platform. I'm using NUMECA Fine Marine 9.2 version.
I've tried to analyse DTMB Combatant both with and without C-Wizard. But in both cases I can't get the same results with the tutorial documents even though I'm doing the exact same things with tutorials.
For example;
In tutorials, the pitch motion monitor (Ry1) decreases at the beginning of the analyse and than starts to increase until convergence which is nearly 15th second of the ships motion. But in my analyse, the pitch motion monitor gives me an increasing linear motion in all process.
The heave motion monitor (Tz0) has a decreasing curve and converges nearly 15th second of the ships motion in tutorials. But in my analyse, the heave motion monitor gives me a decreasing linear motion in all process.
In both monitors, there is no convergence. You can see the monitor comparison in attached picture.
I'm using NUMECA Fine Marine 9.2 version. Can this problem be about the version of the program? Because when I ask a coworker who uses 7.2 version, he said it could be about that. But like I mention above, I'm doing the exact same things with tutorials of NUMECA Online Documentation Platform.
Thanks for all helps.
oab is offline   Reply With Quote
beginner, dtmb 5415, numeca, numeca tutorial
My results become inconsistent when using PIMPLE (nOuterCorrectors>1) instead of PISO FloB OpenFOAM Running, Solving & CFD 5 May 17, 2021 06:17
Validating the results of numerical modeling compared to the results of another model ENG.AHMAD FLUENT 0 June 22, 2020 16:49
bad heat transfer results with low y+ me45 OpenFOAM Running, Solving & CFD 0 April 29, 2020 11:56
Wrong results from motorByke tutorial in OpenFoam 2.1.1 jsc OpenFOAM Running, Solving & CFD 3 April 16, 2013 07:26
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
