Home > Forums > Software User Forums > Fidelity CFD
Time step about forced harmonic simulation
Like Tree2Likes
  • 1 Post By Wout Poncelet
  • 1 Post By chunlong Tan
Old   September 19, 2022, 09:01
Default Time step about forced harmonic simulation
chunlong Tan
chunlong Tan is on a distinguished road
Dear all,
when I chosen Harmonic->Fluid Structure->Mechanical Coupling->Modal->Forced motion to conduct an flutter analysis. I found that there was no imformation about iteration time step. I'm wondering if this type of simulation is not related to the time step, or if I didn't find where to set the time step.
Kind regards,
Chunlong
chunlong Tan is offline   Reply With Quote
Old   September 30, 2022, 10:43
Wout Poncelet
Wout Poncelet is on a distinguished road
Dear Chunlong,
Given that you're performing a flutter analysis and you mention the harmonic, I assume you're running a NLH simulation? Is my understanding correct?
In that case, there is no need to specify a time step (just a CFL number). The NLH method will solve the NS-equations in the frequency domain. Once your simulation is converged, you will be able to reconstruct your solution in space and time, here you can specify the time step and the number of time steps you want to reconstruct.
The imposed forced motion, in case of a NLH simulation, can be constant in time or defined with a given frequency/mean value/IBPA/Real and imaginary part.
I hope this may help you.
With best regards,
Wout Poncelet
colinda1 likes this.
Wout Poncelet is offline   Reply With Quote
Old   October 13, 2022, 02:22
Default Time step about forced harmonic simulationReply to Thread
chunlong Tan
Dear Wout,
Thank you, your answer has completely solved my confusion.
Kind regards,
Chunlong
flutter analysis
Postprocess: sampleDict works but creates no output folder shock77 OpenFOAM Post-Processing 14 November 15, 2021 08:27
Convergence problem of OF WUYing OpenFOAM Running, Solving & CFD 2 September 20, 2021 10:09
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 00:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
