Home > Forums > Software User Forums > Fidelity CFD
Autogrid
Old   August 11, 2003, 14:51
Default Autogrid
ked
Just a little question about autogrid v4.4. How can I easily export, in an ascci format, the meridional mesh in cylindrical coordinates ?
Thanks in advance
Old   August 19, 2003, 10:36
Default Re: Autogrid
Peter Thiel
Dear ked?
You can export every selected face, patch or block from AUTOGRID(tm)4.7-x via the menue FILE -> EXPORT -> Face coor | Block coor | Patch coor to an ascii file.
To convert the cartesian coordinates to cylindrical ones, you can use IGG(tm)4.7-x (Menue FILE -> Convert Data -> Cartesian_Cylindrical).
If you donīt have this version, please contact your support team.
Best regards
Peter
Autogrid: discontinuity of 90 degrees in shroud Eric Joubarne Fidelity CFD 1 July 21, 2009 04:34
autogrid:leading edge liu wangkou Fidelity CFD 2 August 22, 2008 19:42
HELP ME!!! I cannot import blade in autogrid! Nicola Fidelity CFD 2 February 1, 2008 03:38
AUTOGRID and AUTOBLADE strengths and limitations Haider Fidelity CFD 1 December 6, 2007 20:24
About the using of AutoGrid 5 Wheeler Fidelity CFD 0 November 5, 2005 07:05
