Home > Forums > Software User Forums > Fidelity CFD
regrading ven leer fvs
Old   September 11, 2004, 06:21
Default regrading ven leer fvs
amit kumar khatri
i need to know how to implement solid wall and far-field boundary conditions for van leer flux vector splitting scheme, if anyone is aware or can guide me to some reference.
Old   September 21, 2004, 13:17
Default Re: regrading ven leer fvs
khalid sultan
hi: assuming you mean (VAN) LEER; one way of implementing the boundary conditions is by introducing (GHOST CELLS): that is; you generate in your code a group of cells that are taged as ghost cells. Having this done; you should put a (SUITABLE) values of the primitive variables ( rho, u, ...) such that the boundary conditions are satisfied ( in your case [solid wall = no slip] condition ).
The same applies for the far field BCs. The simpliest far field BCs are identified through the method of characteristics (either you copy them from the flow field or simply impose the infinity values ; this depends on the characteristics). If you wish to implement more complicated far field boundary conditions find some thing about the so called "sponge layer".
good luck!
Jacobian Matrix of Van Leer Flux Splitting Vector Jackson Main CFD Forum 2 July 29, 2010 10:57
van leer and cds scheme for LES smc fabian Main CFD Forum 2 March 31, 2006 02:22
Van Leer scheme mer Main CFD Forum 0 February 21, 2004 05:21
