Home > Forums > Software User Forums > Fidelity CFD
Rotor 37
Old   April 9, 2004, 03:11
Default Rotor 37
sunshine
i give the value of k and e like this :114.84375,1619396.7 ,which is caculated in line with the formulation of the NUMECA menu.i am not sure where the problem lies in ,mesh or the boundary conditions.when it runs to the fine mesh ,it just appears the information that reads pressure negative and density negative .
Old   April 9, 2004, 22:26
Default Re: Rotor 37
xingenlu
I think it is the problem of mesh,maybe you should check the quality of the mash such as orthogonality,Aspect ratio, expansion ratio and so on,I have met such problem,good lucky.
Old   April 12, 2004, 09:58
sunshine
thank you a lot !i then try it .i appreciate your kindness.
Did anybody run he ROTOR 67 by using CFX? MouseInMilk CFX 0 August 30, 2006 18:37
Rotor 37 Max MIheev Main CFD Forum 1 October 12, 2005 14:05
rotor 37 sunshine Fidelity CFD 2 October 1, 2004 04:29
about rotor 37 sunshine Fidelity CFD 1 June 2, 2004 08:38
rotor 37 sunshine Fidelity CFD 0 April 6, 2004 21:21
