Home > Forums > Software User Forums > Fidelity CFD
about rotor 37
Old   May 10, 2004, 03:32
Default about rotor 37
sunshine
i am extremely disappointed that i still can't compute the rotor 37 with the low Re model (yang-shih).i even doubt about the new version of NUMECA. i try so many means but eventually i fail to make it go to convergence.can any person give me more guidence ?thank you !
Old   June 2, 2004, 08:38
Default Re: about rotor 37
marc
The rotor 37 test case is used to validate FINE/Turbo code and it is surprising that you can not run it to convergence. I guess the choice of parameters should be carefully checked. I would suggest that you take contact with NUMECA team to solve this out: info@numeca.be.
Did anybody run he ROTOR 67 by using CFX? MouseInMilk CFX 0 August 30, 2006 18:37
Rotor 37 Max MIheev Main CFD Forum 1 October 12, 2005 14:05
rotor 37 sunshine Fidelity CFD 2 October 1, 2004 04:29
Rotor 37 sunshine Fidelity CFD 2 April 12, 2004 09:58
rotor 37 sunshine Fidelity CFD 0 April 6, 2004 21:21
