Home > Forums > Software User Forums > Fidelity CFD
where can I find the theory document?
Old   August 16, 2005, 23:52
Default where can I find the theory document?
boling
Does anyone has the theory documents on EURANUS/FINE?
Old   August 17, 2005, 06:30
Default Re: where can I find the theory document?
john
do you mean the User's Manual?
Old   August 17, 2005, 12:43
boling
No,not the user manual, I am thinking about the documents on the basic algorithm it used in EURANUS/FINE.
Old   September 2, 2005, 15:09
Roque
The theory applied to the algorithms of the FineTurbo software is inserted in the User Manual... actually at the end of each chapter you'll find references for that theory. Please take a closer look to the User Manual. Good luck!
Old   September 3, 2005, 13:19
haitham
where can I find the BS.c lecures
Old   September 21, 2005, 18:47
Hakimi, N., 1997, "Preconditioning Methods for Time Dependent Navier-Stokes Equations" Ph.D. Thesis, Vrije Universiteit
Jameson, A., Schmidt, W., Turkel, E., 1981, "Numerical Solutions of the Euler Equations by Finite Volume Methods Using Runge-Kutta Time-Stepping Schemes," AIAA paper 81-1259
Old   October 13, 2005, 23:20
boling
I have the same question.
Old   November 3, 2005, 12:08
Haitham Q.Hasson
Die Sir,
I'd like to get an application and solved examples in CFD luctutres (using FDM,s and FEM,s)..tha nk you very much
Old   November 7, 2005, 15:45
Default Hakimi,Ph.D. thesis,(1997)
dr. mishal al-saffar
dear sir; could you please download me the following full pdf copy for the Ph.D. Thesis titeled: Hakimi,N.(1997),"preconditioning methods for time dependent navier stokes equations", Ph.D. Thesis, Vrije Universiteit Brussels, Belgium
Old   November 7, 2005, 20:45
Default "FINE/TURBO" commercial code ??
dear sir; could you please download me the full package of the commercial code named FINE/TURBO by numeca int.
Old   June 11, 2006, 03:22
Default Re: Hakimi,Ph.D. thesis,(1997)
  #11
P.A
dear sir; could you please send me the following full pdf copy for the Ph.D. Thesis titeled: Hakimi,N.(1997),"preconditioning methods for time dependent navier stokes equations", Ph.D. Thesis, Vrije Universiteit Brussels, Belgium
Old   June 22, 2006, 00:03
  #12
dr_mishal al-saffar
Dear sir.. can u send me a full pdf copy of this thesis..if u have it ? please i need it .. thankx..
Where to find the theory for weller flamet combustion model 21kalee OpenFOAM Running, Solving & CFD 7 December 19, 2012 17:18
ask for FLUENT 6.3 document autofly FLUENT 2 March 17, 2007 03:57
DOCUMENT EXTERNAL AERODYNAMICS Erdem CFX 0 March 4, 2006 17:48
CFX help document mark CFX 26 May 25, 2001 17:55
the document icmyn CFX 0 May 9, 2001 08:42
