Home > Forums > Software User Forums > Fidelity CFD
the problem about design3D
Old   February 24, 2006, 10:14
Default the problem about design3D
younger
I optimized rotor 37 by fine/design3D. I can suceed in accomplishing Fitting, Screening, Database. However,there is a problem in Optimization model. After importing the .trb file in CFD package, importing a training database and setting objective fuction, there is a warning about "DATABASE FILE/NOT FOUND" when I press process/start. And the optimization can not be run.
Old   March 21, 2006, 10:44
Default Re: the problem about design3D
aji
Dear Younger,
You can send your problem to support@numeca.be. They will be glad to help.
Regards,
Aji
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Help for Fine/Design3D stewart Fidelity CFD 1 September 6, 2006 06:14
Using the Fine/Design3D module yan Fidelity CFD 3 September 6, 2006 06:14
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
a survey on design3d abscissa Fidelity CFD 0 December 1, 2004 02:41
