Home > Forums > Software User Forums > Fidelity CFD
cylinder, drag, onvergency
Old   April 15, 2006, 04:15
Default cylinder, drag, onvergency
num
I have simulated the flow around a circular cylinder using the following configuration (steay, SPALART-ALLMARAS, C,H-MESH (the c-topology defines the inlet), Char. Rey-Number: 140000). But there occur several problems:
1. the convergence history (global residual) is fluctuating - it also happens with a laminar configuration or another turbulence model.
2. I applied the following boundary conditions: inlet=static quantities imposed (to define the velocity Vx=100 [m/s] and pressure 101300 [Pa]). OUTLET=static pressure impoed, SOLIDS WALLS=adiabatic, EXTERNALS=settings from the inlet. Do you principally agree with these settings
4. I would like to calculate the drag - a was thinking about F=m*a but I am not sure how to connect it with my problem.
5. The flow behind a cylinder is not steady - could you explain to me what will I have to do to make it unsteady (boundary condition, mesh generation) -- (I want no rotation!).
Thanks.
drag coefficient of cylinder Avijit FLUENT 12 April 23, 2017 03:26
Drag coefficient of cylinder chenzhi FLUENT 1 December 2, 2008 11:23
drag coefficient of cylinder Libellen FLUENT 10 August 29, 2008 21:56
drag on cylinder dominique Main CFD Forum 1 April 27, 2004 17:08
Cylinder Drag Data Abuzar Abid Main CFD Forum 1 September 5, 2000 07:37
