March 17, 2006, 06:21 |
Error: Failure of connection algorithm
Dear sir, i am solving Conjugate heat transfer problem. while solving i got one error i.e. "failure of connection algorithm". i have given full nonmatching boundary condition to solid wall which is in contact with the fluid. Now what i have to do to over come from the error.
March 22, 2006, 15:28 |
Re: Error: Failure of connection algorithm
Dear Shivakumar,
Did you make sure that both mesh block faces (solid and fluid) are projected on the same geometrical surface? If not, that can be done before setting FNMB in the QuickAccess Pad > Generate > Project Face (fourth button from your left to right). Also, you can perform a check while defining FNMB with the "Compute & Show" button, if no errors are given, the solver shouldn't crash... I hope to help... Roque. |
May 16, 2006, 05:07 |
Hi sheeev, failure of connection is due to the network failure.just check ur lan connection and restart ur system.
Solver failure with error | Sameer | CFX | 4 | December 22, 2010 17:20 |
SolidWorks Connection | andrew mettler hayes | FLUENT | 3 | August 8, 2007 14:48 |
connection with a server | greg | FLUENT | 4 | August 16, 2006 01:26 |
Error: No connection between equations | Reena | CFX | 2 | June 15, 2006 12:11 |
ISAT error and ddasac failure | Stephen Mattick | FLUENT | 1 | July 18, 2003 13:57 |
