Home > Forums > Software User Forums > Fidelity CFD
A puzzle about turbulence of B.C. in inlet
Old   April 26, 2007, 22:05
Default A puzzle about turbulence of B.C. in inlet
Yijin Li
Hi All,
In the Help of NUMECA/Fine7.1, when defining turbulent Boundary Conditions, the help suggests that Vt/v=1 to 5 in internal flows on Spalart-Allmaras Model, but in K-epsilon Model Muit/Mu =50.
I followed this advice. In NUMECA/Cfview, the value of Turbulent Viscosity(Mut/Mu)in inlet boundary in K-epsilon model is 10 times of that in Spalart-Allmaras model.
what's wrong? Is the value of Vt/v between 1 to 50??
Old   April 27, 2007, 20:05
Default Re: A puzzle about turbulence of B.C. in inlet
Yijin Li
How to make a consistent result with Spalart-Allmaras Model and k-epsilon Model? Can someone give me some advices? Thank you!
Old   April 29, 2007, 16:31
Andy Hill
If you are using the S-A boundary condition, you don't define nu_t/nu, you define nu_t itself. In my calculations I have to define a nu_t variable in CFV using mu_t/mu and density, temperature, etc. I have also learned that using nu_t=0 at walls will cause a divergence before even the first iteration of a solution. Ironically, the S-A model specifies nu_t=0 at a solid wall, but nu_t~1e-9 will even work.
I'm not sure if this will help, but I struggled with matching these inlet conditions when I made my first attempt at this. Best of luck.
Old   May 2, 2007, 21:31
Yijin Li
Thank you!
Dynamic Mesh Puzzle Paul FLUENT 1 October 21, 2008 08:47
Some puzzle about the multigrid ztdep Main CFD Forum 6 May 13, 2007 01:52
Geometry/Trigonometry Puzzle RW Main CFD Forum 7 July 30, 2006 10:14
Inlet Turbulence Yazhuo Qian Phoenics 2 March 28, 2003 06:43
A puzzle for the weekend? Robin Bornoff Main CFD Forum 2 May 17, 1999 03:17
