CFView run on the Suse10.2 system has an erro |
when run the CFView on the suse10.2,has an erro: ------------- /bine/uname error while loading shared libraries: libc.so.6 cannot open shared object file: No such file or directory ------------- How to correct this problem?
May be you have just solved the problem but i got the same error. Anyway suse 10.2 is not supported, switch to suse 10. they have different compilers and with 10.2 cfview doesn't work. regards emanuele
Maybe try 64-bit SuSE 10.2. I am currently using FINE/Turbo v7.4-1 on a 64-bit SuSE 10.2 machine and have no problems running it, including CFView. I can confirm Emanuele's CFView problem as we have had the same result on a 32-bit machine. The problem presisted on a 64-bit installation, but we later concluded it could be hardware related. The PC had an Intel motherboard with the 945G chipset, but my current PC has the Intel 965G chipset (Guardfish motherboard, Core2Duo E6600 CPU) with no problems.
Can CFview reads CGNS ? | Vinayender | Fidelity CFD | 11 | May 10, 2011 07:32 |
CFView run on the suse10.2 has an erro | exergy | Fidelity CFD | 0 | August 18, 2007 22:42 |
CFX10 and SUSE10 | John | CFX | 0 | October 28, 2005 09:17 |
cfview in cascade | fishcuter | Fidelity CFD | 0 | February 29, 2004 02:35 |
cfview | fishcuter | Fidelity CFD | 0 | February 29, 2004 02:34 |
