[Sponsors] | |||||
Hi all,
Can CFview reads CGNS file that contains grid and solution data ? Thanks, Vinayender. |
Maybe can't
Thanks Eddy for your response. Recently I found that CFView can read CGNS File if the geometry is written in x,y,z coordinates. But it is not reading if the geometry is written in cylindrical coordinates.. Can any one help me out in this regard. Thanks, Vinayender. |
Dear Vinayender,
Could you use Plot3D format? CFView can read this format. Regards, AJi |
Dear Vinayender,
Generally CFView is supporting 2D and 3D structured multi-block and unstructured CGNS data sets. May you know - CGNS is a general purpose format for CFD data storage and cross system compatibility. As far I could see, there are some information included also in the CFView manual, but maybe not specific anbough for your question. Numeca is refering to http://www.cgns.org for a complete presentation of the format. May this will help? Regards, Stephan |
Dear Aji,
Thank you very much for your replay. Will it also support if I write the Grid in Cylindrical coordinates ? Thanks, Vinayender. |
Dear Aji,
Dear Stephan,
Thank you very much for your replay. I would certainly refer to them. Thanks, Vinayender. |
#9 |
deng qingfeng
Rep Power: 18 ![]() |
The Tecplot or tec360 will help,and it supports CGNS format
#10 |
Vinayender
Thank you all for your replays !!
My porblem got resolved
Thanks ,Vinayender |
#11 |
mistry
Dear Vinayender,
My company is planning to purchase CFD software and for that CFX,StarCD and Numeca we bhave option out of which we want to compare their results with same mesh and boundary conditions can you suggest something how to insert CFX mesh to Numeca? thanks |
#12 |
sanboju
Rep Power: 17 ![]() |
Try to use hypermesh to convert any CFD file in a Numeca file, and viceversa. I used that program to mesh some structures for Abaqus FEM, Nastran and Ansys but I've just read about the possibility of mesh the environment like any CFD. If you try to use Numeca IGG environment you'll see that mesh code is very comfortable and the smothing surface option makes a better mesh with a better flow transfer between cells cheers, Sanboju |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can CFview read CGNS file ? | Vinayender | Main CFD Forum | 0 | May 23, 2008 06:28 |
| CFView run on the Suse10.2 system has an erro | exergy | Fidelity CFD | 2 | September 26, 2007 06:36 |
| CFView run on the suse10.2 has an erro | exergy | Fidelity CFD | 0 | August 18, 2007 23:42 |
| cfview in cascade | fishcuter | Fidelity CFD | 0 | February 29, 2004 03:35 |
| cfview | fishcuter | Fidelity CFD | 0 | February 29, 2004 03:34 |
