July 2, 2009, 04:52 |
problem with translation
Hi!
I have a file X_T( parasolid) to define my blade. The trouble is that it is located too close from r=0. As a consequence, the curve of the hub cuts r=0. So, I have to make a translation. I translate the hub, the shroud and the blade. When I try to link the blade which has been translated, it didn't match with the hub and the shroud in the meridional view. I don' understand because I apply the same translation to the blade , the shroud and the hub. any idea? |
July 21, 2009, 04:59 |
deng qingfeng
Rep Power: 16 |
use the "bulb" Button,and use the bulb function
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
