Home > Forums > Software User Forums > Fidelity CFD
Run two different flows
Old   March 20, 2012, 12:49
Default Run two different flows
Clara
risku9 is on a distinguished road
Hi everybody,
I have to run a simulation with Numeca Fine considering two inlet flows that mix inside a reservoir:
first flow: air.
second flow: oxygen + SO2 with a determined concentration
I'm not really sure if I can do this with Fine. I should be capable of retrieving the SO2 concentration at the outlet.
Thank you!!!
risku9 is offline   Reply With Quote
Old   April 5, 2012, 21:06
CJ
oldshoes81 is on a distinguished road
Send a message via MSN to oldshoes81 Send a message via Skype™ to oldshoes81
Hi risku9,
To run this type of simulation, you will need to use combustion module in your fineopen. 2 inlets with one outlet is alright in this case. You may need a combustion table that describes your thermodynamic properties of your species and this table will only be generated by NUMECA, so i would encourage you to seek for your local representative for help.
Please keep in mind that no reaction will be considered during the simulation.
Regards
CJ
NUMIT Enterprise, Malaysia
+6 017 656 3436
http://maccom-numit.blogspot.com
http://www.numit.com.my
Email : seiko.q@numit.com.my
oldshoes81 is offline   Reply With Quote
numeca, two flows
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 19:44
Batch Run with Initial values file krrishcfd CFX 1 July 28, 2011 02:35
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 12:08
How to run and save tranisent case on Cray XD1 Leon FLUENT 0 October 3, 2006 21:59
problems with LES run Tim CFX 1 February 27, 2006 07:28
