October 11, 2013, 21:34 |
Covective heat transfer plot in Flotherm
1)Does any one know how to get scalar plots of convective heat transfer coeffcient. 2) For any cuboid in flotherm, is it possible to get percentage of conduction, convection and radiation from each surface of the cuboid. Thanks Raghu |
October 13, 2013, 09:01 |
Rep Power: 12 |
Hi raghu,
Yes you can get scalar range of h, use surface plot in the variable instead of temperature keep convective coefficients. And it will get you the values at surface of ur analysis. And one suggestion for your requirement of percentage reduction use the monitor points and iso surface to compare the change in your required variable manually. |
October 14, 2013, 12:45 |
convective plot option
Hi Siva,
Thanks for your reply I am not able to see surface plot in the variable, do we need to enable something before solving. And also I am not able to see convective co-efficient option. Can you please explain it in a bit detail. Thanks Raghu |
January 13, 2014, 20:53 |
SOHYEON MUN
Rep Power: 12 |
convection plot |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Heat Transfer mechanisms | tafaugl | CFX | 1 | November 7, 2012 18:46 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
Non-uniform heat transfer coefficient in Flotherm | bighead | FloEFD, FloWorks & FloTHERM | 2 | June 26, 2009 15:39 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
