June 29, 2014, 23:51 |
valve flow simulation
Rep Power: 13 |
I am simulating a valve moving, watching the delta_p between inlet and outlet. Inlet is constant mass flow rate (water), outlet is constant static pressure. inlet and outlet are extended to have fully developed flow. As the valve moves, the inlet pressure is changing. At close position, delta_p from simulation is 450 psi. But the experiment only gave 250 psi. we don't know where the problem is. Any body have any idea? thanks |
Control Valve Flow Simulation | Ashraf Sharara | FLUENT | 1 | September 3, 2017 09:58 |
Ball valve flow in solidworks | nikesh | FloEFD, FloWorks & FloTHERM | 10 | December 10, 2013 08:40 |
Valve simulation with spring - FSI? Help! | farianka | CFX | 1 | April 17, 2011 18:04 |
Divergence detected in Valve simulation | mehn | STAR-CCM+ | 5 | July 23, 2009 08:38 |
oscillating valve flow | Matthias Finke | Main CFD Forum | 2 | September 10, 2003 13:59 |
