Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
how to enable the Profiles in Flotherm V10 tool?
Like Tree3Likes
  • 1 Post By Boris_M
  • 1 Post By Gabriel_C
  • 1 Post By Boris_M
Old   August 18, 2014, 06:32
Default how to enable the Profiles in Flotherm V10 tool?
Amit
Amit1989 is on a distinguished road
CAn anyone help me out with the Flotherm tool. I am not getting how to enable the Profiles in Flotherm. The graphical out put is not being displayed. Its very urgent. Please do help me out.
Amit1989 is offline   Reply With Quote
Old   August 19, 2014, 01:37
Disabled
Boris_M will become famous soon enough
Hi Amit,
I think there are not so many FloTHERM users in this forum so if it is urgent you might want to contact support for a faster answer. I'm not very familiar with FloTHERM so I wouldn't be of any help.
Sorry,
Boris
Amit1989 likes this.
Boris_M is offline   Reply With Quote
Old   August 19, 2014, 02:44
Default Thanks Borris
Amit
Thanks for the swift reply. Ya I will raise the SR to Mentor Graphics.
Old   August 19, 2014, 04:32
Gabriel Ciobanu
Gabriel_C is on a distinguished road
Hello, just click the profile icon and it should work. But be careful on the next tips:
1. the project needs to be solved
2. you need to have at least 2 iterations for a graphical profile to be displayed (colored lines)
3. in the profiles window click the "Create New Plot" icon
If all of the above don't work try viewing the results (for monitor points) in the "Tables" window.
Best regards, Gabriel Ciobanu
Gabriel_C is offline   Reply With Quote
Old   August 19, 2014, 04:50
Disabled
Hi Amit,
you were lucky :-)
If you are in any need again in future but don't like to explain your problems in the Mentor SupportNet by a lot of text, you can always raise an SR and simply ask them to call you for a question regarding (in this case) Profiles in FloTHERM.
They will then call you and you can explain it easier than writing a long text. The support engineers are just there to do support and every SR will immediately pop-up on their screen in their Support Tool and they will get an email notification. So the initial response time should be pretty quick.
Regards,
Boris
Old   August 19, 2014, 09:47
Default Thanks
Amit
Hi Gabriel,
Thanks for your response. I had already tried those but the issue I am facing is, under the 'Edit>New' in Profiles window I am only able to select the 'Result v distance' option in drop down menu, rest all options are not enabled. The problem persists even after running in many times over.
PS: There are no errors in the message box.
Old   August 19, 2014, 10:40
Gabriel Ciobanu
hello, this might sound strange but... are you sure that you have "monitor points" in your model. only monitor points are displayed under profiles. did you had a look at "tables" tab? there you have the same values for the Monitor Points that are used for ploting.
best regards.
Old   August 26, 2014, 07:07
Gabriel Ciobanu
hello Amit,
after 1 week do you have the answer? can you share it with us?
Best Regards, Gabriel
Old   January 30, 2015, 07:20
Default floeda tutorial files!
Govi
Govindram is on a distinguished road
Can anyone pls share the example and training files!
thank you
Govindram is offline   Reply With Quote
Old   January 30, 2015, 07:23
Disabled
The software installes with the tutorial models and manual for the tutorials.
Old   January 30, 2015, 07:25
Disabled
Oh, wait, that was the FloTHERM post. Do you mean FloTHERM or FloEFD/SWFS?
Old   January 30, 2015, 07:32
Govi
i dont have flotherm or floeda tutorials , or manual. Can you help me!
Old   January 30, 2015, 08:18
Disabled
For FloTHERM there is only a short getting started guide included if you go to the menu "Help" and there "Help Manuals". Anything more is only available through training by FloTHERM reseller or directly through Mentor Graphics.
I would highly recommend to contact your sales contact from who you bought the software as they can give you a very detailed training which is always better than the manuals or tutorials as simply not everything can be in these documents and questions cannot be answered that detailed through them either.
Boris
Heat Pipe SmartPart Features Modelling Flotherm v10 ypooi FloEFD, FloWorks & FloTHERM 1 November 24, 2014 09:57
Tool to download: SU2 post-processing Combas SU2 2 June 5, 2014 14:55
Fluent Vs Solid-works Flow Simulation Mortezab Main CFD Forum 16 July 5, 2013 02:47
Time-Varying Temperature Profiles shepardsp ANSYS 3 October 17, 2010 14:36
Laminar wing profiles and drag gregorv OpenFOAM Running, Solving & CFD 4 December 4, 2007 13:25
