Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Solidworks Flow Simulation crashed when viewing results
Old   November 28, 2014, 18:01
Default Solidworks Flow Simulation crashed when viewing results
John Bulzacchelli
JohnnyOnTheSpot is on a distinguished road
I'm hoping someone can help me with an issue I am having in Flow Simulation.
I can solve my simulation, but when I go to view results Solidworks instantly crashes. This happens most often when I try to view a cut-plot.
I ran Solidworks Rx and found no issues, and am currently repairing my SW install.
Is there a way to generate a crash report to see what is causing the issue?
Here are my system details:
SW2014 SP2
Windows 8.1
ASUS Q550LF Laptop
Quad-core i7 4700U (1.8GHz)
8GB RAM
NVIDIA GT 745M GPU (1GB)
Any help appreciated!
John
JohnnyOnTheSpot is offline   Reply With Quote
Old   November 29, 2014, 05:24
John Bulzacchelli
I finished re-installing SW and this did not solve the problem.
I am open to ideas.
John
Old   December 10, 2014, 03:46
Default Windows log
say_cfd is on a distinguished road
Have you checked the "windows log" through Event viewer ?
say_cfd is offline   Reply With Quote
Old   December 24, 2014, 09:08
Sascha
freierfall is on a distinguished road
Change your grafic gard to a quadro or Firegl and it will work // sorry you have a Laptop.
best wishes Sascha
here is the link certified Card for solidworks
http://www.solidworks.com/sw/support...rdtesting.html
freierfall is offline   Reply With Quote
Old   January 14, 2015, 08:20
Disabled
Boris_M will become famous soon enough
Usually might be related to the graphics card but you should first try to update your drivers as there might have been some updates in the visualization that requires a newer version of some drivers such as OpenGL or something else.
If that doesn't help try if you can show another plot such as surface or trajectories.
Boris
Boris_M is offline   Reply With Quote
Old   October 11, 2016, 04:49
Rita Szijarto
polaritus is on a distinguished road
You should go to Systemoptions --> Performance --> Check Use OpenGL
This should fix the issue with the crashing cut plot.
Be aware that some functionalities of the software will be affected, e.g. if you want to save an animation, you have to check this option out, otherwise you will get black screen only.
polaritus is offline   Reply With Quote
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
Wind Tunnel Flow Simulation Mass Flow BC Issue ledelman SU2 4 August 3, 2014 18:38
Reliablity of SOLIDWORKS FLOW SIMULATION... addy01 Main CFD Forum 1 March 6, 2013 12:12
flow simulation on airfoil using solidworks ravivmis Main CFD Forum 0 April 8, 2012 11:40
exemple of simulation results in reactive flow GACEM_hatem Phoenics 0 June 6, 2001 14:13
