Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Power placement question on a cube
Old   December 22, 2016, 15:20
Default Power placement question on a cube
Octagon1 is on a distinguished road
In FloTHERM XT, I made a 10 x 10 x 10 mm solid cube to go through a simple thermal simulation with convection and conduction only. I applied a thermal attribute of 2W for the cube and tried to place it right at the center of the overall domain. When I meshed and ran the simulation, I get a temperature range of 147 - 152degC on the cube. From that, it tells me floTHERM selects a point on the cube to apply the 2W instead of having the whole cube emit the 2W. The question is how does it determine which spot on the cube to apply the 2W, and is it possible for me to control that?
Octagon1 is offline   Reply With Quote
Old   December 24, 2016, 01:30
Gabriel Ciobanu
Gabriel_C is on a distinguished road
Hi.
The power of 2W is applied onto the entire volume of the cube. The temperature gradient on its surface is normal in natural convection cases. To apply power on a smaller volume (for example a 2mm cube) inside your 10mm cube you just need to make another cuboid, overlap it with the original one and attach power to this smaller cuboid.
One more thing: power can be attached to volumes or to surfaces.
BR, Gabriel
Happy new year to all users
Gabriel_C is offline   Reply With Quote
Cooling cube in a room John_Major System Analysis 0 July 4, 2015 03:24
Explosion inside a cube - blockMesh shangzung OpenFOAM 3 March 6, 2013 03:59
Simulating power sources saisanthoshm88 CFX 2 May 24, 2011 11:46
power spectral density vetnav Main CFD Forum 8 September 3, 2010 14:28
Tip speed, RPM, Power, Wind Speed relationships nabilzhafri Main CFD Forum 0 July 22, 2010 11:28
