Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
FloEFD unable to continue without remeshing
Old   March 17, 2021, 17:08
Default FloEFD unable to continue without remeshing
Chris Kriel
Chris Kriel is on a distinguished road
I am running some simulations using Adaptive Mesh Refinement. It works extremely well. However, I sometimes have the following problem:
After the mesh has been refined I sometimes stop the simulation to look at results. Sometimes, when I want to continue the simulation, the option to 'Continue' is greyed out and the only option is to start a 'New Calculation' and with that the 'Mesh' option is automatically ticked and greyed out, so the only option is for the solver to create a new mesh. All the parts in my model are fixed/mated, so it is not that a part has moved that the solver picked up with the only option to remesh.
So my questions:
1. Any idea why this sometimes happens?
2. If this happens, is there a way of forcing the solver to use a specific mesh, i.e. the previously created adaptive refined mesh? I.e changing some environment variables or editing a text file or something?
Thank you
Chris
Chris Kriel is offline   Reply With Quote
floefd, mesh, new calculation, refinement
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 06:08
How to make a code parallel? Bruno Machado Fluent UDF and Scheme Programming 15 May 27, 2016 09:18
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
2D CFD code using SIMPLE algorithm bfan Main CFD Forum 3 June 22, 2002 22:01
EULER-Forward-Method freak Main CFD Forum 4 June 12, 2001 09:19
