Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Propellar CFD Analysis Questions
Old   December 18, 2008, 09:37
Default Propellar CFD Analysis Questions
Craig
I am attempting to determine the efficiency and forward velocity of a propellar (in water) at a specific RPM rotating around the z axes. For this, I need the following parameters (the associated goals in parantheses):
Thrust force (Z force on prop - surface goal), Torque (torque in the z on prop - surface goal), Rotational Velocity (defined as global rotaton in rad/s), Forward Velocity (velocity in the z - global goal)
I also want to explore the possibility of cavitation so I have set the model up with the above parameters and the following:
Check "cavitation" checkbox Increase turbulence to 1% (typical of most flow tanks) Global mesh refinement of 4 Local mesh (on prop) refinement of 6 Density global goal also added (for cavitation) Velocity Z RRF Global Goal also added Efficieny equation goal
I have set the intial conditions at 0 m/s flow in all directions and seet my calculation control options to finish once all goals are achieved. My travels is still on auto at 0.5.
So - the problem - after 3000 iterations I have still not hit a steady state. This seems odd to me compared to other studies I have done. Is this trypical, and I must be patient, or is something in my set up wrong???
Old   February 25, 2009, 03:35
Default Re: Propellar CFD Analysis Questions
jeremy
You can send me your model with your FLOEFD definition so I can check and confrm your question .
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 12:26
CFD Analysis of pump remith CFX 7 October 6, 2008 07:57
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
Can we quantify the fruits of CFD? Brady Brown Main CFD Forum 14 December 15, 1999 09:42
