Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Flow depending on gravity
Old   November 30, 2008, 15:39
Default Flow depending on gravity
sandy
Hi All. I want to do the flow analysis of a package, where a viscos fluid has to travel only due to gravity.
The package is like a bottle which contains a viscos liquid.I know the outlet pressure and mass flow rate. The liquid flows with gravity. So now i want to optimize the hole dia so that i can achieve my outlet mass flow rate.
Thnx, Sandy
Old   December 9, 2008, 03:03
Default Re: Flow depending on gravity
Alain F
Sound like it is a free surface flow problem. In this case EFD can't do the whole job since the level of the flow will vary with the flowrate and flowrate depends on flow level throught the pressure head.
If it is not you can have your result by applying a pressure drop accross the outlet equal to the pressure head.
If you have a free surface you can do the job with EXCEL : determinate the pressure drop coefficient of your outlet with EFD software or IDEL'CIK pressure drop reference book (if its geometry is simple). With the pressure drop coefficient you can calculate the massflow rate vs time with a simple integration.
regards
Old   January 17, 2009, 09:26
Default Hi People!
Immurlnum
Hello People,
I Just joined up and am trying edit my profile but i can't see the button!! probably staring me in the face lol
thanks guys
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Low Speed flow in Micro Gravity; what model? Brice FLUENT 0 June 13, 2007 10:30
VOF gravity flow BC Alexander Ladino CFX 1 March 28, 2007 14:45
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Gravity influence of flow :Urgent Suresh Balasubramanian FLUENT 3 August 6, 2003 11:06
