Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Pressure loss in PEM cell with different profiles
Old   April 11, 2009, 15:47
Default Pressure loss in PEM cell with different profiles
Rodrigo
rodrigoscf is on a distinguished road
Hello.
I'm a student of Mechanical Engineering and I'm trying to project a PEM cell.
Now, I'm studing the influence of different profiles into pressure loss.
THE SOFTWARE IS COSMOS FLOWORKS
For now, let's focus in a common serpentine.
I have working pressure and inlet volume flow rate.
I put as bondary conditions, the inlet volume flow in the inner face of inlet cavity and at the outlet cavity, I put static pressure and pressed 'OK'.
As inicial conditions, I put the inlet face and accepted the entries. P and T default, defined previous at Wizard.
I choose, than, Static Pressure at inlet and outlet surface. And Global Goals velocity and density.
I run the solver.
Next I put everything in Floworks calculator.
I want to know if I can trust in this way of getting pressure loss... Am I right?
I believe that it will give me the inlet pressure that I need to choose a pump.
Sorry for my english and for the big text... but I'm trying to learn the software by myself.
Thanks for everyone...
Rodrigo.
rodrigoscf is offline   Reply With Quote
Old   April 14, 2009, 10:00
Ivan Dergunov
GadskiyPapa is on a distinguished road
Originally Posted by rodrigoscf View Post
Hello.
I run the solver.
Hi, you are making all right, but I don't understand, why you use inlet face as inlet conditions?
In FlowSimulation (Formely Cosmos FloWorks) you can define initial conditions in the GeneralSettigs>Initial Conditions. There are possibility to define temperature, pressure and velocity. For some special cases you can use Local initial conditions.
For obtaning values of pressure drop you can use Equation Goals={SG Static Pressure Inlet} - {SG Static Pressure Outlet}.
GadskiyPapa is offline   Reply With Quote
floworks pressure drop
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
Pressure loss in a combustor Anand Main CFD Forum 0 April 28, 2003 09:33
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Pressure at the surfaces of a cell Gao Main CFD Forum 6 January 8, 2001 19:58
