Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Airfoil design in solidworks/floworks
Old   May 31, 2009, 10:19
Default Airfoil design in solidworks/floworks
Manuel
zelito is on a distinguished road
Hi guys,
some time ago I found a very nice guideline for airfoil design in Solidworks that could be useful for some people here.
http://www.dur.ac.uk/g.l.ingram/down...ofoilGuide.pdf
take a look in the link.
It's quite simple and useful if you use data from airfoils data files.
Cheers
zelito is offline   Reply With Quote
Old   September 3, 2009, 11:00
Hamed Rasouli
hamedhpt is on a distinguished road
Originally Posted by zelito View Post
Hi guys,
It's quite simple and useful if you use data from airfoils data files.Cheers
Thanks.It was so useful.
but how can we get the coordinates of an airfoil?
hamedhpt is offline   Reply With Quote
Old   September 3, 2009, 12:00
Manuel
hi!you have two options. Either you measure or you can look in here:
http://www.ae.uiuc.edu/m-selig/ads/coord_database.html for example.
Old   September 4, 2009, 03:54
Hamed Rasouli
Oh my god.Thank you very much zelito.
Old   January 27, 2010, 12:33
dik
diki
dik is on a distinguished road
great zelito.. what a database!!
dik is offline   Reply With Quote
Old   January 30, 2011, 10:27
Default Airfoil design in Solidworks/Floworks
Scott Vader
Vader is on a distinguished road
Hi All
I've posted a Solidworks macro at 3D content central that creates wing sections from the UIUC database. It will also create 4 digit and 5 digit NACA wing sections directly from the equations.
Wing Section Maker
comments welcome.
Scott Vader
Vader is offline   Reply With Quote
Old   February 8, 2011, 23:26
Archana
Archana is on a distinguished road
A detatiled "How to do CFD analysis in a butterfly valve ?" is what i am looking for..
It would be kind of you if you could help me...
Thanks and regards
Archana
Archana is offline   Reply With Quote
Old   February 9, 2011, 07:30
Disabled
Boris_M will become famous soon enough
Hi Archana,
from your last posts in the CFX forum I could find what you are trying to do.
If you know how to work with configurations in SolidWorks then it's easy to create several configuration, each with a different valve angle and each configuration can be a simulation project. The Projects in FloEFD are configurations and you can change an angle and apply this change only the configuration you want it to be associated with. That way you set up one project with all the project definitions such as CV, Torque and other goals and then clone it and apply each angle to one clone (configuration) and start the whole set of projects in a batch run.
That way you get all necessary data points for your valve curve.
For the large angles you often can use the same mesh settings but for smaller ones you might want to check if the mesh is good enough.
Use the equation goals to enter the equation for CV but consider the unit conversion when switching between units that have different magnitudes and would result in x-times the value of CV if not considered since FloEFD does only calculate with the values and not with the units, it's basically just a letter behind the value.
I hope this helps.
Boris
Boris_M is offline   Reply With Quote
Old   February 9, 2011, 23:16
Archana
Thank you you the good hint
the batch processing is what i have been trying to implement but getting no where ..the major problem in doing what i am trying is the basic modeling of the valve is done in another software ..So i do the assembly in solidworks and carry out the simulation..
so creating one project at one certain angle i am able to get a simulation but for varying angles is where i get lost...And Batch run is what i am trying to do but not sure how to perform it
Old   February 10, 2011, 04:26
Disabled
Hi Archana,
Ok, I understand. So if you have your first simulation project defined and checked that the mesh is of a good quality you check if the angle for the valve is set with a constraint in SW. They are called mates and have the symbol of a paper-clip in the design tree. If there is no angle mate that defines the position/opening of the valve you should create one. Usually if you import geometry you don't have mates and would have to define them yourself. It is the easiest to fix all parts that are not moving or rotating by selecting these parts, then right click on the selected parts and chose "fix". with that all selected parts are fixed in space and you can now define an axis and angle for rotation with a mate. To do so select the mate feature in the assembly feature list and for the axis you simply have to select the two cylindrical faces where your valve disc is hinged. For the angle it is the easiest to select two planes, one from the valve disc and the other from a fixed part. Then you can select the angle definition in the feature and set an angle.
Now click on the angle mate in the tree to mark it and you will see it appear in the CAD area. Click now in the angle in the CAD area to highlight it and then double click it so a small window "Modify" opens up. Here you can change the value and apply it in general or select the small dropdown button on the bottom right of the window where you can choose if you want to apply the value to either "This configuration", "All configurations" or "Specify configuration".
Now if you have a project already defined make sure you have the project as active configuration and then use in the Modify window "This configuration" for the value you want to simulate in this project. Then clone the project and rename the project ideally with the corresponding angle and also modify the angle after you've cloned the project to "This configuration" again so the new angle is set for the cloned project. And so on...
At the end you should have several projects and when double clicking the different configurations in the configuration manager you should see the valve angle change automatically. Now each project you have has its own angle applied.
To start the batch run now go in the menu bar in "Flow Analysis" and there in the extension "Solve" where you find "Batch Run...". Here you see all the projects listed and you can either select them one by one for which to calculate or click in the top row for "All Projects" on what you want the solver to do (Mesh or Solve etc.) then you can also select how many processors to use for the projects and you can put the projects in a certain order by selecting the projects and use the up/down buttons on the left. If you have several cores available and several licenses you can also do for example 4 projects simultaneously with one core for each project on a quad-core computer and have them being solved simultaneously.
I hope this helps,
Boris
Old   February 11, 2011, 00:43
Archana
Thank you so much
the information was very useful
i ll try it the way you have suggusted and let you know about how far my answers are coming
Thanks and regards
Archana
Old   February 15, 2011, 00:24
Default Thank you
  #12
Archana
Thank you so much the procedure you gave me was very helpful.. i performed a batch run for 6 varying degrees successfully .
Thanks for the useful information
Thanks and regards
Archana
Old   February 17, 2011, 01:13
Archana
MR BORIS
Thanks for the help was useful
I have a small problem..
WHen i performed the angle mate in the first case i was able to change the positions of the vane by its desired angle position in the configuration tree..
but lately in another project after performing the angle mate i am not able to change the the vane position from one configuration to another..
i save the configuration using clone project (eg 40 degree) and create another angle position for say(60degree) . then when i try accessing the 40 degree configuration it displays only the 60 degree configuration.. i am confused where i am going wrong could you let me know where the mistakes could be
Thanks and Regards
Archana
Old   February 26, 2011, 16:33
Disabled
Hi Archana,
I would guess you accidentally said to apply the 60 degree to all configurations. That might be the reason why your newly defined 60 degree are also set for the 40 degree project. Try the other projects too. Maybe they are also on 60 degree, that would confirm this theory.
Boris
Old   March 1, 2011, 04:08
Archana
In the dimention small tab i selcted "this configuration" and did the same procedure as suggested and got the required movement
Thank you once again for the useful information
Old   March 24, 2011, 21:00
mohammed glal
iglal is on a distinguished road
thx very much
I draw my airfoil now
iglal is offline   Reply With Quote
troubled by my airfoil design radix FLUENT 3 December 25, 2008 09:18
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
Airfoil design khairy FLUENT 6 April 28, 2005 18:19
Airfoil Design CLmax Main CFD Forum 0 October 9, 2003 02:01
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
