March 17, 2011, 10:59 |
Solving a NACA0010 in Floworks
Nick
Hi everyone,
I'm new to this forum! I hope you guys can help me, I've been having some issues with Floworks and I can't get to any solution… I need to solve this as soon as possible! I'm trying to design a wing, so, as it's the 1st time that I use Floworks, I decided to first test it with something I know before getting into proper simulation. This is why I'm using the NACA 0010. I need to find lift and drag coefficients at 6º angle of attack. This is what I did: •*Sketched the aerofoil using 2 equation-driven lines (equation for a 4-digit NACA found on wikipedia) • Rotated the sketch about the origin by 6 degrees • Extruded the sketch • Opened up the Floworks Wizard… selected External flow, AIR, Laminar Only, Velocity in the x-direction 15 m/s, precision 3. • Run the project. Once it's done, I right-click Surface Parameters, insert… Select all the faces and choose Force and Shear Force. Now, the Lift will be Force + Shear Force in the y-direction, while the drag will be the Force + Shear Force in the x-direction. To find the 2 coefficients, I use the equations: CL = 2*L/(density*surface_area*velocity^2), CD = 2*D/(density*surface_area*velocity^2) I get something around this: CL=0.11, CD=0.02. It can't be correct! I expect values close to CL=0.7 and CD=0.004! Where am I going wrong??? Please help me with this! Thanks, Nick |
March 23, 2011, 06:18 |
Niels
Rep Power: 15 |
I have the same problem.
I tried to simulate a wing in 2D and did not get any satisfying results. In 3D the drag coefficient may deviate a lot from the profile date due to the induced drag. (however i doubt if floworks is able to simulate induced drag very well) I have tried a lot of settings but never got really close to the right values (for example i got 25% of the lift than calculated on paper). I just think that floworks isnt the best option for wing simulation. But it could be usefull when you dont have acces to other programs. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
