Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Heat Sources
Old   June 16, 2011, 10:14
Default Heat Sources
Chris
HUTCH is on a distinguished road
I am currently trying to work out the effects on my 128 heat sources.
Do i have to create 128 individual Heat Geneation Rates for each 1 ??
It seems i do but i am hoping there is a way around this.
When i just do them as a lump i dont get the results i want or it doesnt seem to treat them as indiviudals.
HUTCH is offline   Reply With Quote
Old   June 28, 2011, 12:25
Disabled
Boris_M will become famous soon enough
Hello Hutch,
no, this is not necessary. When you have 128 heat sources with each the same amount you can simply select them all and creat a single source with 128 times the value and it will be distributed evenly on each selected item.
If that doesn't work properly please contact your support and let them check your issue.
Boris
Boris_M is offline   Reply With Quote
floefd pro 9
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Time Dependent Heat Sources Leon Mills Phoenics 1 July 3, 2001 05:22
