Home > Forums > Software User Forums > FLOW-3D
sediment scour
Like Tree3Likes
Old   October 22, 2012, 20:28
Default sediment scour
bird
pyxbird is on a distinguished road
All dears,
Hi, I am trying to use sediment scour model to simulate the scour patter around a vertical cylinder under steady flow. And here are my quetions:
1. I know the meaning of critical and cohesive sediment fration, but I don't know how to define the values of them.
2. As we all know, we can define the seabed by--initial--fluid region--the sediment concentration--packed, here the value of packed=density of the sand(for example 2.65)*solid fraction of the sediment? And if it is true, so how to define the value of solid fraction of sediment(1? or 0.9?and so on).
3.In the fluid region, we also need to define the fraction of the fluid, if the solid fraction I input is 0.9, so the fraction of the fluid should be 0.1 of 1? When I choose 0.1, after the simulation is run the fluid above the seabed drops straightly down to the "seabed", but when I choose fraction of fluid=1,there is no problem, but I don't think it is reasonable(can there be such large amout of water in "seabed"?), so how to define the value of "fraction of fluid"?
4.After the simulation is done, how can I see the flow pattern in the tab "Analyze"? Is it like this: iso-surface--packed sediment concentration; color variable--strain rate? But I can't find more detailed information, for example the scour depth.
I will be grateful is someone can help me.
pyxbird is offline   Reply With Quote
Old   October 23, 2012, 10:59
Jeff Burnham
JBurnham is on a distinguished road
FLOW-3D v9.4.x includes packed sediment depth and rate of change in depth as output variables that can be used as the color variable when plotting packed fraction as the iso-surface. If you have an earlier version than that, you may have to experiment to find a good way to plot.
JBurnham is offline   Reply With Quote
Old   October 23, 2012, 11:02
Jeff Burnham
The solid fraction of the initial regions is the same as the 'maximum packing fraction' defined on the Physics dialog for the scour model. The different proportions of sediment are used to calculate the fractions of each species in that already-known solid fraction. Always set the fluid fraction = 1.0; even in the initial fluid regions: the sediment (both suspended and packed) is considered a two-phase mixture fluid, and that fluid must be 100% present (F = 1) in all submerged cells, otherwise there will be many pressure failures and collapse of the fluid.
Old   October 23, 2012, 20:00
bird
Thank you JBurnham, you have helped me many times.
Old   April 25, 2013, 05:49
mahdi
mahdi1 is on a distinguished road
Hello pyxbird & JBurnham
I simulated a channel with movable bed by v10.
Could you please tell me that how can I take a plot of bed deformation and also How can I obtain maximum depth score in results file?
I would be thankful if you help me.
mahdi1 is offline   Reply With Quote
Old   May 2, 2013, 15:20
mahdi
Originally Posted by pyxbird View Post
All dears,
Hello pyxbird
Could you please send me your prepin file.
Because I want to do same study.
I would be thankful, if you can help me.
Old   May 8, 2013, 02:59
bird
Originally Posted by mahdi1 View Post
Hello pyxbird
Sorry I didn't surf the Internet in the past days, I simulated that case last year and the prepin file is lost. And I will continue the work few months later.
Old   May 8, 2013, 03:07
bird
Firstly you should define a bed in Meshing&Geometry, and after the simulation is done, in Analyze Tab, 3D, you can find the bed height directly.
lamnguyen11b2 likes this.
Old   May 15, 2013, 11:30
Smile A case caused by stokes wave acting on a mobile bed
周傳傑
elite1989 is on a distinguished road
Hello everyone,
I am a Flow-3d 10.0 user.
I am simulating a scour case caused by stokes wave.
The simulation is no error and warning, i want to show the mobile bed in the same way with the figure.2 ( from this address: http://www.flow3d.com/resources/news...our-model.html )
I have already tried the Packed sediment height and the Total sediment solid fraction, but it didn't work.
In Physics-the sediment scour, i only changed the quality of Diameter and Density, is it right?
In output, i only choose the Fluid velocity, Hydraulic data and Sediment concentration. Is there anything i didn't notice?
I also want to take the data of bed height, what option should i take?
Please do me a favor, i appreciated!!!
elite1989 is offline   Reply With Quote
Old   May 15, 2013, 13:50
mahdi
Hello elite
about graphical output:
I have same problem too.
But you can see bed deformation as follows:
Specify a name for sediment species,
after that, you can find this name in Analyze, 2-D, Counter variable ,.......... choose it
no velocity vector for vector type
Render
This is a way to see bed deformation.
If you could find another method, please inform me.
about diameter and density,
you can do a sensitive analysis according to below paper:
http://www.flow3d.com/pdfs/tp/wat_en...ions-07-13.pdf
Old   May 16, 2013, 05:35
Smile
  #11
周傳傑
Thank you, Mahdi.
I took your advice to analyze the simulation,
but the results don't look like the pics from the website i posted last time.
Why can't it be as clearly as the fig.2?
I would like to make my mobile bed showed in one color with boundary line.
Whether the failure reason is that i didn't choose the enough items in output data before simulate?
If yes, what should i take?
Thanks a lot for your paper about the density and diameter.
It do me a big favor!!!
Old   May 16, 2013, 16:46
mahdi
Originally Posted by elite1989 View Post
Thank you, Mahdi.
Hi
As I told you before, I have same problem too.
If you could find a solution, let me know.
Regards,
Mahdi
Old   May 16, 2013, 17:31
mahdi
Hello
Thanks for your reply.
I have a big problem yet.
I simulated local scour around pier. But my results don't seem to be correct. (please see attached picture).
I also attached my prepin file. I would be thankful if you tell me what my mistake is.
I really appreciate any help you can provide.
Old   May 21, 2013, 08:46
mahdi
Hello elite
Do you have experience about local scour around pier?
Old   May 21, 2013, 16:05
mahdi
All dears,
Hello pyxbird
Could you please post your prepin file about local scour around pier.
Because I am also working on that. I need your experience to create my model.
I really appreciate any help you can privide.
Old   May 25, 2013, 02:06
Smile hi Mahdi
  #16
周傳傑
Hello elite
I am sorry, Mahdi.
My lab just have some experiences about the scouring on seawall.
I have a prepin file from my friend, it's about the scouring around pier.
Do hope it will give you a hand.
Have a wonderful weekend.
Old   May 27, 2013, 07:21
mahdi
I am sorry, Mahdi.
Hello elite
Thanks for your file.
Did you see results of that file?
That file is according to below paper and its results are different with results of this paper.
http://www.flow3d.com/pdfs/tp/wat_en...flow-23-09.pdf
Do you know that what is because of this difference?
or Could you please ask your friend about that?
Also Do you know that how I can obtain maximum scour depth exactly?
Thanks
Old   June 1, 2013, 23:26
bird
Hello pyxbird
Sorry, my prepin file is deleted. Because I ran the simulation last year, and the result was bad. And I am not good at this part, I am sorry. But later maybe in July I will focus on sediment scour, after I learn more about it, and t I can discuss it with you.
Bird
June 2nd, 2013
Old   August 10, 2013, 15:12
Default sediment Hight
  #19
hossein
hossein_sml is on a distinguished road
Dear Sir,
I am using Flow3d V9.3.2 for simulating scouring. How can I measure sediment height and scour profile at Flow3d V9.3.2?
Thank You
hossein_sml is offline   Reply With Quote
Old   December 10, 2013, 09:22
Default scour under submarine pipeline
  #20
miss miti is on a distinguished road
I Model a submarine pipeline in flow3d, but it doesnt show any scour under pipeline, it will appreciate if you could help me to find out whats wrong with my model. & also which out put is useful in scour models?
sycst911 and ludosbiz like this.
miss miti is offline   Reply With Quote
Sediment Scour model mshotm2000 FLOW-3D 1 February 6, 2014 20:30
Sediment Scour model mshotm2000 FLOW-3D 3 March 16, 2011 07:06
Sediment Scour model mshotm2000 FLOW-3D 2 February 4, 2011 03:54
about sediment scour model great1427 FLOW-3D 2 November 18, 2010 04:38
Sediment Scour Ghirghidov FLOW-3D 7 October 20, 2009 03:21
