Home > Forums > Software User Forums > FLOW-3D
Flow-3d fails to launch
Old   November 14, 2012, 09:45
Default Flow-3d fails to launch
Mark Storrings
mstorrings is on a distinguished road
Users are not able to launch Flow-3d 10.0 when authenticated on a Windows 7 machine using domain credentials that usalize a roaming profile.
The roaming profile appears as a UNC. It seems as though Flow-3D is trying to access the profile by fails to work with the UNC.
Is there a way, via environmental variables or something similar, to bypass Flow-3D access the users profile and instead utilizing a folder on the local hard drive?
mstorrings is offline   Reply With Quote
Old   November 14, 2012, 11:09
DTS
David Souders
DTS is on a distinguished road
Dear Mark,
Please email support@flow3d.com and let them know the organization you are with and how to contact you. They can help with this issue.
Thank you,
DTS
DTS is offline   Reply With Quote
Old   November 16, 2012, 07:20
kkh
Kjetil K. Heggernes
kkh is on a distinguished road
I had the same problem. Solved it using the following steps:
1. Start Registry Editor
2. Open the following key: HKEY_USERS\S-1-5-21-305035777-899029998-720635935-79877\Software\Microsoft\Windows\CurrentVersion\Ex plorer\User Shell Folders
3. Change the value of ‘Personal’ to a folder on your local hard drive (e.g. C:/Users)
kkh is offline   Reply With Quote
Old   August 14, 2018, 10:09
Bruno Lebon
blebon is on a distinguished road
Old post, but I encountered the same problem today. Can be easily solved without messing the settings for other software that rely on that UNC path by editing the registry as follows:
1. Launch regedit.exe
2. Go to HKEY_USERS/S-1-5-21-(a long series of numbers which is different in your machine)/Software/Flow Science/C:flow3d|v5.0u1
3. Edit the field UserFilesDirectory to a non-UNC path, e.g. C:\Users\(your username)\Documents\FLOW-3D\
blebon is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Different flow patterns in CFX and Fluent avi@lpsc CFX 6 April 17, 2012 01:22
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
