Home > Forums > Software User Forums > FLOW-3D
Baffle
Old   March 1, 2013, 03:35
Question Baffle
wusuhong
wusuhong is on a distinguished road
I am doing a side weir project, i want to get the flow rate through the weir.
Setting up a baffle is the method, right?
however, how to set up the baffle?
Is there anybody can help me?...Thanks very much.
wusuhong is offline   Reply With Quote
Old   March 1, 2013, 04:03
FHydro
flow_CH is on a distinguished road
go to meshing and geometry then baffles the right click on baffles then choose add then check define as flux surface then type 1 to porosity in porosity properties. then you can define it on your project in limiters.
flow_CH is offline   Reply With Quote
Old   March 1, 2013, 04:07
wusuhong
I did as the these steps before, but the result Q=0, for many times.
Is there any tips when set up the baffle?
Old   March 1, 2013, 04:14
FHydro
read flow 3d 's manual.may be you can find it.
Old   January 31, 2024, 03:36
brianallen
brianallen is on a distinguished road
Setting up a baffle is a method for measuring traffic through the weir. Baffles are used to create an even flow and help measure water volume more accurately. To set up the baffle, you need to determine the appropriate size and location to ensure water flow through the weir without being affected by other factors. You can learn more about baffle setup through the documentation or seek help from experts in the field.
angel numbers
brianallen is offline   Reply With Quote
[snappyHexMesh] handling of baffle regions or surfaces with zero thickness with snappyHexMesh StSchiff OpenFOAM Meshing & Mesh Conversion 5 March 8, 2017 09:45
Boundary baffle error 258 Nalleli Siemens 2 November 19, 2006 13:14
Grap Fluid Cells Just On One Side Of A Baffle Tommy Siemens 0 May 7, 2006 07:49
baffle in flow route GaryWang CFX 0 October 23, 2005 23:19
Determining alpha and beta for porous baffle Liaqat Khan Siemens 1 October 27, 2000 04:44
