Home > Forums > Software User Forums > FLOW-3D
VFR (Q) boundary condition
Old   June 11, 2013, 03:03
Default VFR (Q) boundary condition
morteza
(morteza) is on a distinguished road
Hi all dears,
I want to use VFR boundary condition in my simulation. In fact i want to use a volume flow rate such as a pump to exit flow in my domain with distinct flow rate. could you pleas, how i can do it?
(morteza) is offline   Reply With Quote
Old   June 12, 2013, 08:35
michael barkhudarov
MuxaB is on a distinguished road
Originally Posted by (morteza) View Post
Hi all dears,
What version of FLOW-3D are you using?
MuxaB is offline   Reply With Quote
Old   June 15, 2013, 01:22
morteza
hi
flow-3D V.10.0.1
thank you
Old   July 14, 2013, 02:04
michael barkhudarov
This can be done in two ways. Either a mesh BC or a mass sink. A mesh BC is simply defined at the mesh edge, choose VFR BC, set the flow rate, set the direction of the flow - done!
A mass sink is defined using a geometry component. Define the component (e.g., a disk), and set its flow rate to a negative value.
Michael
hi
flow-3D V.10.0.1
thank you
Old   July 15, 2013, 02:03
morteza
hi, prof. michael barkhudarov
thank you for your reply, but in VFR BC, you can only enter flow into domain not exit from domain. we can only determine direction of entering flow to domain not exiting flow from domain.
Old   July 15, 2013, 11:08
michael barkhudarov
Not quite. While the flow rate is always positive, the direction of the flow is defined by the flow direction vector: positive - into the domain, negative - out of the domain.
Old   July 16, 2013, 04:06
morteza
Dear Prof.
Thank you for your reply, my problem solved. I have another question: It is possible to draw 2D streamline in flow3D, similar to 3D streamline?
best wishes
Old   July 16, 2013, 18:38
michael barkhudarov
I don't think so
Dear Prof.
best wishes
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Radiation interface hinca CFX 15 January 26, 2014 17:11
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Opening Boundary Condition andreachan Main CFD Forum 11 March 19, 2013 16:46
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
