December 5, 2019, 21:37 |
Error when applying the Gaussian heat source
Zeqi Hu
Rep Power: 9 |
Hi, everyone:
For the welding simulation, I want to apply a Gaussian heat flux on the free surface cells. I modified the rhoe(ijk) density*specific of the free surface cells in the qsadd.F90 subrutine, the temperature could increased correctly at first several seconds, but when the temperature exceeded the melting point, the solver run into an error, the time step and stability limit was not stable, and the fluid even disappeared in the 3-D postprocess interface, what's wrong with it? Sometimes it shows the error message: heat transfer/conduction flux exceeded stability limit. Is the error caused by the frees surface cells? and why the error occurred when the temperature exceed the melting point exactly? Thank you. |
December 15, 2019, 15:50 |
notsureitrightornot
Xuesong
I think you can try a two-fluid simulation. The one fluid with void is less physical, maybe there's some uncovered technical details.
---- 2020.12.31----- I find i didn't activate the surface tension model. Now it works with one fluid with surface tension model on. There's no negative temperature error occurred. Last edited by xuesong; December 31, 2019 at 18:47. |
welding simulation |
Heat source on the surface of the wall | Vishsel | OpenFOAM Running, Solving & CFD | 2 | April 27, 2020 09:59 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
