Home > Forums > Software User Forums > FLOW-3D
Quick question-extract volume
Old   June 5, 2014, 08:49
Default Quick question-extract volume
Akshay Kumar
Akshay is on a distinguished road
Hey guys
If I have initialized(t=0) a region in my overall domain with some fluid-1, how can I get the volume of that region?
Akshay
Akshay is offline   Reply With Quote
Old   June 6, 2014, 02:12
Akshay Kumar
It'll be great if someone could give me a quick solution. It is a bit urgent!
Thanks!
Old   June 23, 2014, 03:32
Maxime
macsim is on a distinguished road
Maybe by lunching simulation and check variable "volume of fluid" at t=0 ?
macsim is offline   Reply With Quote
Old   June 30, 2014, 01:53
Akshay Kumar
Hi Macsim
I do not want to run the solver to find out this data.
I can use FAVOR to visualize this region...so on similar lines is there a way to extract the volume without running the solver and by running only the preprocessor?
Thanks
Akshay
Old   July 5, 2014, 20:44
Jeff Burnham
JBurnham is on a distinguished road
Choose 'preprocess the simulation' from menu at the top. It only pre-processes, and does not run. The output from preprocessor only is prpgrf.xxxx, where xxxx is the name of the project. Go to Analyze tab & open prpgrf.xxxx. Go to Probe tab and select General History Data. In that list, select total volume of fluid (or similar name, based on your version of FLOW-3D). Select 'text output' button at the bottom, then 'Render'.
JBurnham is offline   Reply With Quote
Old   July 7, 2014, 05:44
Akshay Kumar
Thanks Jeff!
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
VOF model - volume fraction residual question Wim Heirwegh FLUENT 9 July 8, 2013 13:44
a question about volume fraction bill CFX 1 September 19, 2003 23:37
