May 28, 2017, 09:51 |
PostProcessing of particle source
Rep Power: 12 |
I've seen some papers which show the mass momentum source model in a nice way in flow-3d postProcessing. A large number of particles are generated in the void region and move all the time dynamically.
How can I get such an effort in the visualization? Is it necessary to use flowSight? or flow-3d postProcessing is robust enough? |
June 1, 2017, 07:16 |
Rep Power: 12 |
I think I should ask for a more recent version
October 24, 2017, 08:15 |
Panomdei
you can do that by a plugin in 3dsmax software, called particle simulator I'm guessing, a very powerful simulation tool for particles.
Engineering software tutorial |
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 14:22 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
Check particle impaction with User Fortran | Julian K. | CFX | 3 | January 12, 2012 09:46 |
