Home > Forums > Software User Forums > FLOW-3D
Surface Roughness Problem
Old   December 15, 2014, 03:23
Default Surface Roughness Problem
RoyDaniel
hydr_eng1805 is on a distinguished road
Dear All Flow 3D Modellers ,
Now I am creating models of simple open Channel which its length is 200 m with various Surface Roughness. To input Surface roughness, I just used the equation which is mentioned in the users manual "FLOW-3D Documentation, Release 10.1.0" page 409. the input symbol is k which is derived from manning's , Rh (Hydraulic adius) and Dh (Hydraulic Diameter). As my mannings are 0.035 and 0.05 and my channel size is 25.5 m width and 10 m depth, hence it yields k = 0.5886 ( for n = 0.035) and k=2.602 ( for n = 0.05). Then , I have make running for those two value of k ( surface roughness), but unfortunately both results show the same value of water depth ( please see figures on attachment files), according to my knowledge in open channel they should have different water depth result. Could anyone help me to give some comment that I may have made some mistakes in this model?
Thank you so much
Best Regards,
Roy
hydr_eng1805 is offline   Reply With Quote
Old   December 15, 2014, 06:19
Serhan Aldogan
Serhan Aldogan is on a distinguished road
Dear Roy,
Is it possible that something with physics is wrong?
Serhan Aldogan is offline   Reply With Quote
Old   December 15, 2014, 08:29
Default Dear Sehran
RoyDaniel
Dear Sehran,
I think you're correct, it may have mistake with Viscosity and turbulence. Let me check first , then I will let you know.
Thank you so much Sehran ..
Cheers
Roy,
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
free surface problem with capillary effect rabbitmelon CFX 25 August 16, 2013 03:05
Problem in specifying the boundary condition for tank's surface which is on fire BHE FLUENT 1 March 21, 2013 23:02
open channel problem (free surface) Andy Chen FLUENT 4 July 10, 2009 01:20
