Home > Forums > Software User Forums > FLOW-3D
problem with the entrainment coefficient!
Old   May 10, 2017, 10:00
Unhappy problem with the entrainment coefficient!
Hydreaulic structures
hamidciv is on a distinguished road
hello Dear friends
i've been working on sediment scour caused by submerged jet, i've got the wide range for sediment scour parameters e.g. critical schields, bedload coefficient, entrainment coefficient,..., as far as i know, getting “ good results” should not lead to the violation of the physics.
otherfore, i need to know the acceptable range for the entrainment coefficient as i got it equal to 1 in my work and the results are nearly good, but i'm concerned because this mentioned value does not fall within the acceptable range(physical range). also, i searched this issue on documentation & manual of flow-3D, but, i did not succeed to find it. i well know that default value is 0.018. But it, in what range could be located? if there are references about the acceptable range, please introduce them.
Maybe anybody can help me!
best regards
hamid
hamidciv is offline   Reply With Quote
Old   May 13, 2017, 09:18
could somebody help me, please?
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
pressure coefficient problem (FLUENT) pimpin FLUENT 8 March 24, 2014 22:37
drag and moment coefficient problem josip76 FLUENT 3 June 12, 2011 10:45
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
diffusion coefficient problem wanghong FLUENT 0 April 7, 2005 21:26
