Home > Forums > Software User Forums > FLOW-3D
how to draw a contour plot in flowsight?
Like Tree9Likes
  • 2 Post By Harold.
  • 1 Post By hamidciv
  • 1 Post By Harold.
  • 1 Post By Harold.
  • 2 Post By Harold.
  • 1 Post By Harold.
  • 1 Post By Harold.
Old   February 11, 2018, 01:43
Unhappy how to draw a contour plot in flowsight?
Hydreaulic structures
hamidciv is on a distinguished road
Hi Dear users;
i've simulated the sediment scour due to horizontal jet, I want to draw the bed profile contours over time in 2D&3D view.
whether flowsight is capable to do this? I also know that Tecplot software can do this but unfortunately, I have never worked with it so far.
I would greatly appreciate it if you could help me!
best regards
hamid
hamidciv is offline   Reply With Quote
Old   February 13, 2018, 15:33
Can anyone help me?
i would really appreciate any feedback you can give me.
thanks
Old   February 14, 2018, 18:16
Harold
Harold. is on a distinguished road
You can do that using FlowSight.
Once you have your results files (flsgrf.*) open it in FlowSight and follow the next steps:
1. Open the results file with FlowSight:
File > Open... (flsgrf.*)
Choose Selected timeline in the Timeline options (Is necessary to have results file with Selected Data, See Output Tab in FLOW-3D GUI)
2. Add Packed Sediment Geometry (In your case is bed component)
Choose the component you want to see (This is the packed sediment component) on the Geometry List panel checkbox.
If you can´t see the Geometry List panel just go to: Window > Toolbars/panels > Geometry List
You can add color as a constant (constant color) or the best option is to add Packed Sediment Net Height Change as a color to the component:
In the Geometry List panel go to: Geometry List > Color by > Packed sediment Net Height Change Selected
Now you can see the whole packed geometry (bed) in 3D varying according to your scour or deposition results
I recommend you to Modify the color scale. Click-right on Color bar > Modify... > Edit Palette > Editor Scale and choose Earth
3. Adding Fluid Surface:
You now can also include the Fluid Isosurface. Just go to Isosurface List panel > Choose Fluid Selected under Surface column
This Isosurface could be colored by Velocities: Isosurface List panel > Color by > Velocity Selected or whatever avaliable variable
I recommend you to add transparency to the Fluid Isosurface in order to see clearly both fluid and bed. click-right on Isosurface > Transparency
4. Creating 2D - clips:
This is good way to visualize, in a 2D plane, any plane that you want in order to plot packed sediment component (bed) in time.
Go to: Create > 2D Clips... Choose between X/Y/Z or Arbitrary planes. In color by > Fluid Fraction Selected
Click on check box Show advanced > Blanking > Variable Fluid Fraction Selected and click on Create button
You need to Hide, previously, the Isosurfaces, Geometry or anything that you have made before or to assign an adequate Transparency in order to see the new 2D Clip just created.
5. Creating 3D - Clips
Is quite similar to 2D clips with its corresponding variables.
I hope these steps help you, sometimes is dificult to explain using only words. If you have any questions please let me know.
And please share with the community an image or video of your post-processed simulation!
Good luck!
hamidciv and thunde47 like this.
Harold. is offline   Reply With Quote
Old   February 16, 2018, 13:34
Dear Harold;
i really appreiate you for your detailed response & time. I've attached an image from my output results as you wanted.
with the best wishes
hamid
thunde47 likes this.
Old   May 3, 2018, 12:15
Hi Dear experts/users
I've been trying to show the simulated results as shown in the figure below. but unfortunately, I was not successful so far. is flow3d's post processor or flowsight can do this?
I would greatly appreciate it if you kindly give me some feedback on this.
best regards
hamid
Old   May 5, 2018, 22:22
Harold
Dear Hamid, I ran a sample simulation to explain how you can set it up the results that you want to show:
FLOW-3D´s Post-Processor:
You can do it using FLOW-3D´s post-processor:
1. Analyze > 2-D > Contour type > B/W Contour Lines
2. Analyze > 2-D > Contour type > Number of contour (Set an adequate number)
3. Analyze > 2-D > Data Source > Selected
4. Analyze > 2-D > Limits > Z: (You have to select the adequate Z plane in order to see the right plane)
5. Click on Render
Please see the attached image: "Scour - Contours Setup 2D" and "Scour - B&W Contours".
You can also select Shaded Contours:
1. Analyze > 2-D > Contour type > Color Shaded with Contour Lines
Please see the atached image: "Scour - Shaded and B&W Contours"
FLOWSIGHT:
You can also use FlowSight to obtain several critical data for this kind of simulations. The following images shows the steps to setup a different ways to obtain data or visualization:
1. You can only show the final geometry after the scour or sedimentation process. There is not variable colored.
Attached image: "Scour - FlowSight - Only Final Geometry (Bed)".
2. Net Height Change on the bed surface:
Attached image: "Scour - FlowSight - Net Height Change (Bed)".
3. You can also show contours lines in FlowSIght, using the Palette Type: Banded, Right Click-on the color bar, then modify and set the adequate values.
Attached image: "Scour - FlowSight - Net Height Change (Bed) Banded - Gray"
Attached image: "Scour - FlowSight - Net Height Change (Bed) Banded - Modify Menu"
4. Interactive Probe to get data information for bed level on that point.
FlowSight - Main Menu Bar: Query > Interactive Probe
Attached image: "Scour - FlowSight - Net Height Change (Bed) Banded"
5. You can also analize the physical behaviour using Streamlines, in this case is showed a Line as an emisor of those streamlines.
FlowSight - Main Menu Bar: Create > Streamlines...
Attached image: "Scour - FlowSight - Net Height Change (Bed) + Streamlines"
Attached image: "Scour - Net Height Change (Bed) + Streamlines"
Note: You can see the other images in the next Post, because of number of attached files restriction on this forum.
I hope this info help you, if you have questions please write a post using images, just like this one.
hamidciv likes this.
Old   May 6, 2018, 11:37
Dear Harold,
I really appreciate your clear and accurate guidance. that was exactly what I need.
Kind regards;
hamid
Old   May 7, 2018, 03:02
Dear Harold, thanks a lot for your very thorough explanation.
I've another favour to ask you. I want to show the generated scour hole in profile view and plan view (in terms of quantity) to compare them against experimental values. i've attached the simulated results in different views.
would you please advise me how to extract the following results in the form of quantity(value)?
I wish you all the best.
hamid
Old   May 7, 2018, 21:36
Harold
Dear Hamid:
You can use the measure interactive tool in FlowSight:
For a better visualization you can use 2D and 3D clips to see the plane/profile that you want.
Or you can extract data, point by point (as available), using a graph plot:
Go to: Create > Probe... > Line probe
So you can show a graph fo the Net Heigh Change of bed vs. distance (for a determined time). That distance is from the begining of the line vector (black) until the end (head-cone) of the line vector.
I think this last option is the one that you wanted, am I right?
You can add your experimental results on this graph using a csv or txt file, following the text rules which are located in the documentation. Then you can compare it point by point in the same graph.
If you are comparing whit experimental data you have to be sure you set the right parameters for shield number, diameter, density, the right bed transport equation (according with the spectre/range of applicability) etc. You have to obtain all these data from actual/real world!
You can also export a STL file (CAD) with the new (calculated) bed/surface geometry, including scour or depositions; then you can compare it with your experimental results using a CAD software.
Don't forget to share your results with the community!
Regards,
hamidciv and oyhr2010 like this.
Old   May 9, 2018, 02:52
Dear Harold, Thank you for all your help!
yes, you are quite correct, the profile view of the scour hole/deposition can be obtained simply as you mentioned above. but unfortunately, I did not understand how can I extract the plan view of scour hole as a set of point outputs?
best of luck
hamid
Old   May 9, 2018, 19:33
Harold
Dear Hamid:
You have to follow the next steps:
Go to: Create > Probe... (click-on)
Select case: your results case
Then select the Line probe option in the drop-down list
Choose Select option in the Line probe setup field
Now you can see a black line vector over the geometry, this vector will extract the data point by point along its own definition, in other words: the initial part of the line extract the zero position in the graph and the head of the line will extract the data of the end (distance: x axis).
This line vector should be in horizontal position in order to extract the right data point by point. Please see the image below. Z1=0.3 and Z2=0.3
If you need to modify the direction of the line vector, you can use the Tool:line panel to edit/modify its position. There you can rotate, move, align etc. Please see the image above to see how to access this Tool.
You can select Use Mesh option to extract the data based on the mesh that you set up in FLOW-3D.
So, now you have to select in the Variable Name box the variable that you want to extract its values, in this case is Packed Sediment Net Heigh Change Selected. You will notice a blue circle/dot in the left side of the variable name which indicates that this variable is already selected and ready to plot.
And finally you need to push the New plot button located in the Add to field.
I hope these instructions are helpful.
If you have problems with this, please share an image with your doubts.
Regards,
Old   May 10, 2018, 04:48
Dear Harold, thanks for your attention & quick response!
I'm sorry if I did not make my intention clear enough. based on what you mentioned in the recent post and before, the probe feature can only be used for bathymetry along the line which we define it. I want to show the perimeter of the generated scour hole as highlighted (red colour) in the attached figure.
lately, i've encountered a strange problem that I wanted to kindly ask you. I've extracted the deposition height value using 2D clips & probe methods, and the results were different from each other as you can see in the attached picture. this made me very confused.
I'd really appreciate it if you could advise me on my probelms.
best regards,
hamid
Old   May 12, 2018, 20:27
Harold
Dear Hamid:
Please see the post that I made before (5 May - Post #6 and #7), in that post I shared some images showing the plane view contours lines using both FLOW-3D Post-processor and FlowSight, there you can find their value using every plane in Z or using Interactive Probes and Banded Palette in FlowSight.
These are the normal ways to compare the perimeter of the scour-hole (plan view), so you can put this image over your experimental results using a right scale factor.
Other way is to use a CAD software to compare both numerical and experimental results; you can do this generating a STL file (CAD including final bed geometry) from FLOW-3D Post-processor (Please see 5 of May post) or using FlowSight.
I guess that you want to plot the contour lines (perimeter) in a graph (I think the only reason for this is because you have the experimental data in a text file), so other thing you can do is extracting the data points that you need into a text file (please see the image below). In this case you can get every point of the results according the Limits that you set in X,Y, Z and Time.
Regarding the max/min values in FlowSight, you have to be sure you are plotting the same plane (2D Clip) - line vector probe, you have to select the right plane because is a 3D proble and there are a lot of max/min points. (Please see the image below)
Another thing you have to set is the min/max for the current viewpot, you have to set the color bar with the current information, for this right click-on the color bar to open the menu and set the values for the current viewport, in the next image you can see how to open this menu.
I also have an observation about the last image you have shared, I personally don't think this is a good way to visualize the Net Height Change of the bed because you colored the fluid and not the component (bed), and the component is the one that is actually changing, so for me it makes more sense to set color (Net Height Change) to the component not to the fluid. The next image shows what I am saying. Note: The last image (Scour - 2D Clip Data Probe Min Max) was set according your image just to let you know how to set the min/max value, but this is not the best option to visualize like I said before.
I hope this works for you.
If you still have problems to visualize correctly please share an image.
Cheers!
Old   May 13, 2018, 15:43
Dear Harold, thanks a lot for your consideration & time!
I've some questions/doubts regarding what you mentioned in the previous post as follows:
1- I've set the min/max to the current viewport as you pointed out, and the problem was solved.
2- I would like to know your opinion about the best way to extract the Net Height Change of the bed. I think the probe method can be suitable to do this. if I'm wrong, please correct me. I've been searching for finding the most accurate way to extract this parameter for a long time.
3-unfortunately, one of my problems has not been solved yet. I want to extract the perimeter of the generated scour hole in longitudinal and transverse coordinates. To clarify the issue, I've shown what I mean in the attached picture.
All the best,
hamid
Old   May 31, 2018, 11:09
Hi Dear experts,
can somebody help me with this problem? I want to extract the perimeter of the generated scour hole as shown above.
kind regards
hamid
Old   April 1, 2020, 22:11
Default how to plot streamlines?
  #17
Nurul Iffahaziati
Nurul Iffah is on a distinguished road
hello everyone, I would like to ask how to plot streamline in flowsight? can anybody help me?
Nurul Iffah is offline   Reply With Quote
Old   June 9, 2020, 23:39
Default How to created streamlines plot in flow3d
  #18
Adilar Titon
Eng Brazil Flow 3D Adilar is on a distinguished road
In this video as tutorial how to created streamlines in flow3d flowsight https://www.youtube.com/watch?v=u8fj...ature=youtu.be
Eng Brazil Flow 3D Adilar is offline   Reply With Quote
Old   March 22, 2023, 13:12
KHALID EL ABBAOUI
ELABBAOUI is on a distinguished road
Dear Harold,
I hope you are doing great while reading my text
I was searching how to extract yz coordinate from a contour and or 2D Clip in Flowsight and I found your help hear.
I will be very gratful if you could help me to extract yz point by point a contour or 2D clip to make comparaison with different simulation in FLOW-3D
ELABBAOUI is offline   Reply With Quote
y+ contour plot through flow domain Katha CFX 5 July 20, 2017 07:38
How to Contour plot for omega_z ?? snehal OpenFOAM 3 March 11, 2017 05:41
generating 2d-planar contour plots from a contour plot on a curved surface alinik CFX 3 May 21, 2016 06:17
udf diffusivity in contour plot Lilly FLUENT 0 July 29, 2014 08:40
contour plot help jesse@uconn FLUENT 0 February 15, 2010 19:05
