Home > Forums > Software User Forums > FLOW-3D
multi-block mesh problem
Old   February 12, 2019, 19:48
Default multi-block mesh problem
Farzam is on a distinguished road
Hi all,
I am working on simulating a large pond with several inlets and outlets. Thus, I use multi-block mesh, but a velocity disturbance starts to grow on the inter-block boundaries and spread throughout the domain.
For finding the source of the problem, I decided to make the problem simple, so I simulated a 10m*10m*2m pool with 0.9 water elev. without any inlet or outlet. There is no wind, and no initial vel. It has 2 linked mesh blocks with sizes of 0.5m and 0.25m (Aspect ratio is 1 for both of them). All of the BCs were left as default (symmetry). We expect the velocity remains zero, but after 1000 sec the disturbance starts and after a few seconds it takes over the whole domain.
I already increased Inter-block boundary type coefficient (alphamb), but it didn’t help. Smaller mesh size and different turbulence model didn’t help either. Other configurations of mesh blocks (nested or overlapping) also cause the same problem
Does anyone have an idea why this simple simulation has this error?
Thank you!
Farzam is offline   Reply With Quote
Old   February 13, 2019, 17:50
Ali
Fast&Furious is on a distinguished road
ِDear user
That is due to interpolation error between blocks. By choosing 1:2 mesh size ratio, and increasing alphamb, and putting the interblock boundary somewhere with less p and v gradient you can only decrease it.
To me this is a big problem of Flow3D that needs to be resolved!!! F3D guys may have a better response for you.
Fast&Furious is offline   Reply With Quote
Old   March 15, 2019, 12:34
thunde47
thunde47 is on a distinguished road
Try alphamb = 1e-6 and alphamb = 1.0. See if the problem is resolved by setting one of these values.
thunde47 is offline   Reply With Quote
[foam-extend.org] Foam-extend-3.1 on RHEL: mesh problem lxwd OpenFOAM Installation 4 March 25, 2017 16:10
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
