Home > Forums > Software User Forums > FLOW-3D
Flow cannot pass through fan/impeller component
Old   June 1, 2021, 11:46
Default Error: forrtl: severe (157)-Flow cannot pass through fan/impeller component
NGUYEN DUY TONG
Thomas Nguyen is on a distinguished road
Hi everyone, I'm using Flow3D-v12 to simulate the air flow passing well-turbine in Oscillating Water Column.
I'm using fan/impeller component to represent well turbine.
Pipe: radius=0.3m, Length=1.1325m
fan/impeller object properties: outer radius=0.3, Spin rate=209.44 rad, Accommodation coefficient for rotational velocity Ad=987 1/s, Axial velocity coefficientBd=0, number of blades =8, thickness=0.13125m. Fan located at x=0.49m from inlet.
As we know, fan/impeller component is treated as phantom component. However, The result shows the flow cannot pass through this object in my simulation and there is an error:
forrtl: severe (157): Program Exception - access violation
Could you please give me advice about this problem?
Thank you
Last edited by Thomas Nguyen; June 2, 2021 at 12:23. Reason: addtional information
Thomas Nguyen is offline   Reply With Quote
Error: Update failed for the setup component in Fluid Flow CFX nudi1001 CFX 4 January 17, 2023 03:01
Interaction between open channel flow and porous flow narendrapatel111 ANSYS 0 June 8, 2020 11:42
Will the results of steady state solver and transient solver be same? carye OpenFOAM Running, Solving & CFD 9 December 28, 2019 05:21
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
