Home > Forums > Software User Forums > FLOW-3D
Serious problem in water level & fluctuations!
Old   September 11, 2021, 10:13
Unhappy Serious problem in water level & fluctuations!
Hydreaulic structures
hamidciv is on a distinguished road
Dear all;
I want to investigate the flow structure around a complex bridge pier in an open channel with 15 m length, and 1.26 m width (water depth is equal to 28 cm). Additionally, it should be noted that the experiment has been conducted over a rough fixed bed. My problem is that the flow does not reach a steady state. Also, the results show that water level tend to increase, and there are fluctuations on the water surface. I've considered a variety of B.C at inlet & outlet of the domain, but it was useless. The corresponding results can be seen in the attached pictures.
Are there any solutions or suggestions to solve this problem?
Thanks in advance
Hamid
hamidciv is offline   Reply With Quote
Old   September 13, 2021, 14:17
zohran arif
zohran is on a distinguished road
if you know the velocity in the channel try these B.C : xmin as volume flow rate with fluid fraction 1 , xmax as velocity with fluid fraction 1 and stagnation checked OR xmin as volume flow rate with fluid fraction 1 and xmax as outflow
zohran is offline   Reply With Quote
Old   September 14, 2021, 02:00
Dear Zohran,
Thanks for your attention & response. I've tried these B.C before. It also should be noted that I have only water height at the outlet. This problem frustrates me a lot.
Best wishes,
Hamid
Interaction of disc rotation and water jet impingement problem Prahar_S13 FLUENT 0 March 31, 2021 14:45
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 19:24
interFoam current, Why Water Level decreases in time Jekke123456789 Main CFD Forum 1 April 12, 2020 03:53
Virtual wave problem at ship calm water simulation xdo2004 STAR-CCM+ 1 March 20, 2020 23:19
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
